Uconnect installation
Scott Buker
Chattanooga, TN
I changed my radio to the uconnect 5.0. The navigatgion says no signal. What do I need to do?
rotwiler
Washington
Do you have a gps antenna? Sat uses a antenna on different frequency. My 13 with a 8.4a only had a gps antenna, so I had to buy splitter for the fakra and put a magnetic sat antenna on metal under dash to get sat radio. My truck had uconnect deleted and sat radio deleted on invoice but I still have a hidden gps antenna somewhere in truck since it works great.
S
Scott Buker
Chattanooga, TN
I have the 5.0 The antennas were color coded. Does anyone have a schematic of how the system works?
duunoit
EcoDiesel
I think there is a 5.0 that has NAV but it is for a FIAT. Never seen one in a Ram (if it would even fit).
duunoit
EcoDiesel
Not that I don't believe you, but can you post a picture of it (or even better, what is the model number)? Do you still have the environmental controls like the other 5.0 RA2? Thanks
mike19950
Delaware
Yes the compass module is housed in the overhead console. It also has to be activated by the dealer for it to work.
S
Scott Buker
Chattanooga, TN
I installed the uconnect 5.0 radio. I need to install the mirror with microphone also. Do I need to buy the wiring harness for the mirror also?
mike19950
Delaware
I found one on ebay that came out of a 2015 Dart that fit on the windshield mount and plugged right in. Works perfect. You just need to be careful apparently there are different types of windshield mounts that are not compatible with each other. Here is the part# from my mirror #68102484AA
Fpye
