You shouldn't have to set anything up each time you get into the truck. I just get in and turn the truck on and the voice command stuff all works. It just takes about 30 seconds to load and then I can use it.
Sent from my iPhone using Tapatalk 2
Yea man, I'm sorry you have to deal with all that. I guess that's the problem with technology that is so new...usually it works great but everyonce in a while it doesn't work at all.
With my LG phone, it takes a couple attempts to set it up with the U-Connect system.
I have not had any luck with the USB port in the glove box. Try the USB port on the front.
I have also found that to transfer music on, it will not work with a USB. I have to put the music on my mp3 player, then plug it into the AUX port.
Then, of all the music I have on there, I keep hearing the same songs. Over and over. Not too happy with this system. Is there an upgrade for it?
Tried my moms iPhone 4 and 4s, both gave errors most of the time, 4 connected once.
Sent from my Nexus 4 using Tapatalk 2
