Uconnect updates
Redsloten
St. Louis, Mo
2016 Rebel
Hello,
I just recently purchased a new to me 2016 ram rebel. It has the 8.4 vp4 uconnect radio. When I do the vin search online it shows uconnect is up to date. The version I’m currently running is 16.09.09 which I believe is out of date. I just purchased updated maps for the navigation and it won’t let me update them until software is updated. Where should I start?
R
Redsloten
St. Louis, Mo
2016 Rebel
I already did and it states it’s up to date. But I don’t believe 16.09.09 is up to date.
turkeybird56
Central Texas
Hello,
It tells me mine is up to date, and I know it is not, they are in the 17's, and my U Connect on Uconnect 4 radio is original from when I bought truck in 2018
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
know that i need to update my 2016 Ram
Uconnect_VP4,18.45.01-My13-17
The dealership is going to do the update tomorrow
You could call the number below & ask them what the latest update # is
In This Version: Should you encounter any issues with your update, please contact the Uconnect customer care center at 1-877-855-8400, and press # to reach a customer support technical specialist. Canadian residents , call 1-800-465-2001 (English) or 1-800-387-9983 (French). For residents outside US and Canada please contact your local dealer. Once the file is done downloading, double click the 7z file to extract. For further instructions, refer back to the *Downloading the update* section.
If calling that number does not seem to help. contact https://www.here.com/navteq
cj22944
CA
Hello,
I just did the update from 17.09.01 to 18.45.??? On my 17 ram. Lost my aux input and can't play streaming music thru Bluetooth. Very frustrating
Sent from my SM-G981W using Tapatalk
dieseldave
Little Suamico
I just tried to update also. I downloaded the lasted 18.45 ? . My radio will not let me install it. I called their customer service and they told me to go to the dealership. WTF.
GTyankee
3.0 ecodiesel
therein lies the problem
Rams Engineers wrote the update & it may have a flaw ?
Uconnect or Driveuconnect just sends the update out to the satellites
When it does not work, for whatever reason, they want you to take the issue to the dealership, who is actually is an independent dealership selling Mopar products, so you get stonewalled on a fix
Then a Regional Representative for Ram needs to be brought in, if you raise enough of a rucas for the dealership to call for them to intervene
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Hello,
The firmware you need can be found in this thread...
https://www.ramforum.com/index.php?posts/1125807
dieseldave
Little Suamico
I downloaded the 18.45 update to a flash drive and it will upload to my truck. I called and they told me to go to the dealership. How much this cost me. Very disappointed.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
What country are you in? The update is meant for North American market radios.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
GTyankee
3.0 ecodiesel
I pick my Ram up in the morning
They are doing a radio update & an oil change
Fingers crossed that they did not brick my radio
