ramffml
- Joined
- Jul 12, 2019
- Posts
- 3,648
- Reaction score
- 7,614
- Location
- ramforum
- Ram Year
- 2019
- Engine
- hemi 5.7
Again… The higher the ratio, the more effort it takes to turn in the lower the ratio, the easier it is to turn. I don’t know why that’s so hard for you to understand.
There are 2 sets of gears at play; the gear in the transmission, and the rear axle ratio. Both of those combine/multiply to make your final gear ratio at the wheel. You're stuck at thinking the rear axle ratio is the only thing that matters, without understanding that the transmission can downshift and make more torque that way.
It's why I told you to ride a bike; you'd discover that you can change either the front gear or the rear gear to make more torque.
