Slayer12
Hey Guys,
First time on the forum. Hoping you guys might have some ideas for me, because I am pulling my hair out. I have a 2012 hemi 5.7L with 120K miles on it. About 1K miles ago it developed a squeak/squeal/chirp sound at idle and at very low speeds. It only does it when the engine if fully warmed up. Initial cold start, there is no squeak.
I have eliminated the belt, belt tensioner, and all pulleys. When the noise started I went ahead and threw a new belt and tensioner on it, thinking that would resolve the issue. When it didn't, I ran the engine with the belt fully removed for a short time and they noise was still there. So I know it isn't a pulley either.
After this I did some research and came across a video where the squeak was caused by the harmonic balancer. The rubber develops a crack and when rotated can cause a squeak. I bought a stethoscope and sure enough the noise was coming from the front of the engine down by the crankshaft. Looked at my balancer and it was cracked in the same manner that I found on the video. Done deal! Except I replaced the balancer and the squeak is still there.
At this point, I have eliminated all moving components on the front of the engine and am at a total loss as to where this noise is coming from. I can't imagine any internals such as main bearings or anything of that nature would make a squeak/chirp noise.
Any thoughts on where to go from here? TIA
