Troyshobbyfarm
Has anyone ever updated to power folding mirrors and used the factory switch.
I take it that you can't use your existing mirrors and just order the two modules and door switch. Would love to get rid of my tow mirrors, or at least be able to fold them with a switch. But for $1600? WowI went from non auto folding tow mirrors to folding regular mirrors om my 2017 Rebel. Here is where I got them. Just drop in the new modular, put mirrors on and they send the device to program them. Not cheap, but well worth the hassle of folding/unfolding everyday to get in/out of garage.
infotainment.com
i
If you keep your eyes open you can normally find a used set for $150-300. Then you would need the door modules, about $100 and the door switch about another $100. You can then buy the obd genie for $300 or use the AlphaOBD. All in, if you find the right deals, you should be able to do it for about $400 give or take.
yes your completely right in what you say but I never knew there was another set of door modules until recently. I kept looking but never seen any postings stating that until now. HAHA, everyone just kept telling me I needed the LER sales code from the dealer. When I went to the dealer they looked at me like I was stupid and that code doesn't exist. But alas I have power folding mirrors. You should put your latest post on its own feed for people to find easily.To anyone wanting to add the LER power folding mirror code it can only be done by the dealer on certain trim levels of trucks. The code is in your BCM but it is blocked from their view and they cannot enable it. That being said it CAN EASILY be enabled using the alpha tool in a matter of minutes. Many of us have successfully done it. Of course you will need the correct door modules and master door switch as well. I reccomend checking out the alpha obd app thread to anyone interested in installing power fold mirrors. It can also be used to add many other options the dealers cannot.
The 13 to 17 mirrors have the outside temp sensor on the drivers side mirror, the 09 to 12"s do not. If you install a 09 to 12 drivers side mirror on a 13 or newer Ram your outside temp will automatically default to -40° because the truck cannot detect the outside temp and you may also get a check engine light.Along the same line - does anyone know if the 09-12 mirrors are compatible with electronics from a 17 truck?
I know the seats arent, but wasnt sure about mirrors (power, heat, power folding and auto-tilting)
Thanks.
If you have an express you have to change door modules.I changed mine.Thanks I was kind of confused because my door modules have the extra port for the power fold mirrors, but they still don't work by changing this setting. Mine is an express and I didn't even look at the module pn when I had the doors off. I just assumed that the original mirrors only had one plug where the power folding have two, but it did have the extra port on my stock door modules so they would work. I guess I will need the 68225102AC/103AC modules
