Ok Nick, what's the difference between the green and yellow ? Thanks
Green Stuff Brake Pads
EBC Brakes Green Stuff brake pads are designed for trucks that see heavy braking because they’re resistant to brake fade, which is when a brake pad loses stopping power due to excessive heat from heavy and/or repeated use. Green Stuff brakes also have the following benefits:
Designed for Heavy Braking: Brake pads resist brake fade on vehicles that see heavy braking.
Medium Dust: Less dust than OEM brake pads means low wear and tear on rotors.
Yellow Stuff Brake Pads
The high-friction, high-heat formula of
EBC Brakes Yellow Stuff brake pads is designed for trucks that see extreme braking, frequent towing, and/or for trucks that are equipped with larger tires and wheels, because they’re highly resistant to brake fade. When used for this type of driving, you can see up to 30% improved stopping power over OEM brake pads. Other benefits include:
Designed for Extreme Braking, Frequent Towing, Larger Wheels & Tires: High-heat, high-friction formula is best for vehicles that see frequent towing or have larger wheels and tires.
Wide Heat Range: Able to absorb more heat in heavy braking situations, such as aggressive driving, towing and hauling.
Yellows will dust more but have more bite
