Upgrading Radio from RA1 to RA4 w/o going to single zone ATC
USPatriot1776
Kentucky
Hello, I am looking to upgrade my truck's radio from the base RA1 to the RA4. I currently have the new RA4 on its way to me. However I am running into an issue, my truck does not have steering wheel audio control.
I started an order on infotainment for this bezel:
I know this bezel requires a T-harness for the volume knob to work, how could I go about making a T-Harness for the radio and or splicing the volume controls into it?
Any help would be much appreciated
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I highly recommend that you do not get this bezel and instead install the steering wheel audio controls as your first step with the intention of installing the factory bezel later.
The bezel mentioned has a volume control prone to failure.
670hoth
Maine, USA
I upgraded to RA4 and bought a used leather wrapped steering wheel with controls for $140. This being said, for me, volume on the steering wheel alone is just not enough. I will buy single zone ATC when i can get a good deal on the bezel and module.
Athlium
Tacoma, WA
3.0L EcoDiesel
I went the way with just trying to have steering wheel controls first.. and that was not enough.
Bezel you can probably get a single zone ATC or maybe even no ATC.. but you'll probably need conversion harness to go from RA1 to RA4.
USPatriot1776
USPatriot1776
Kentucky
Yeah I canceled this item on infotainment and instead went with the single zone atc kit they have on there. It is a little expensive but I could not find the HVAC module or a single zone ATC bezel that was in decent condition anywhere.
USPatriot1776
USPatriot1776
Kentucky
I installed the RA4 radio I bought off of ebay (it was originally in a jeep). Everything works pretty good, I just get the phone error due to not having the cellular dummy connector installed. Next step is to update the map and the software. Thanks again for the reply.
Yep, I figured it out before it shipped. Just went with the single zone kit from infotainment everything works well so-far! Just waiting on the bezel and hvac module. Thanks for the reply
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I "think" the cellular dummy connection no longer works anyway (after a specific update?)
USPatriot1776
USPatriot1776
Kentucky
Yeah, its not a huge deal for me but I did get the radio in and my single zone atc bezel should be in tomorrow from infotainment. It does suck as I haven't been able to use the radio since you cannot control the volume without the bezel. I did hear some things about the sharkfin antenna mod, curious as to what that does? I know it likely adds "cellular" functionality but I don't think it can be activated.
