V10 enginissuesue
Justin1656
New york
V10
This damn engine. I've got the problem narrowed down to the fuel system, I hope. I've replaced new sensors, relays and fuses and a new fuel pump but the pump isnt getting power. I've tried jumper wires to see if Its just a bad new fuse/relay. In doing so I realized the relay is a 5 pin but there is no wire or connector in the holder. In assuming since everything is how it was when it was in the old truck it will run like this. I dont understand why the pump isnt getting power and what to do to get power to it. Also can this be the reason it wont run, because it starts anand runs for a second or 2 with starting fluid.
