Validation of checksum failed
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
In process of tuning my truck with FRP. I'm downloading the stock tune from a fresh unlocked pcm and get :
Validate checksum failed. File unusable.
This is after it spent 9 minutes and 30 seconds downloading the engine file and 3 minutes 45 seconds downloading the transmission file. Both downloads were successfully completed.
I have mpvi4, fresh from hp tuners, the 2018+ unlock cable from hp tuners and an unlocked pcm, calibrated to my truck.
Truck runs perfectly no codes, but this problem. Anybody ever experienced this and your thoughts on solution? Hp tuners is working on it but it's now with their programmers????
Bigskyroadglide
Bigskyroadglide
Moderator
Try downloading again. Checksum fail indicates the number of bytes in file do not match what it is supposed to be on the good file sent.
If that doesn't cure it, contact supplier to check it. Sometimes some ad blockers can interfere with the download.
No joy, 3rd download, same outcome, deleted all apps, deleted any third party programs, virus detection. Downloaded hp tuners for the third time, since they update daily. Different cable. Starting to think it could be pcm
Trying a different older computer later today.
Maybe its because mercury is in retrograde in my rising sign?????
Tuned half a dozen rams, never had this trouble.
Bigskyroadglide
Bigskyroadglide
Moderator
Just heard from hp tuners, elevated to engineering, their support team and programmers can't figure it out. Could take a few days
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Sounds like your internet is a little on the slow side but you said you have done several tunes.
Just curious if all or any was done at your now location for loading & reading tune.
Makes me think internet connection not linking with HPtuner while trying to read pcm.
If not the above sounds like pcm is still locked out to you somehow.
Bigskyroadglide
Bigskyroadglide
Moderator
Well, I haven't tried a different internet, that could be another possibility. I'll try that, can't hurt. Nothing else has worked
crackerjack1957
Check Wi-Fi signal strength on your phone & laptop in the vehicle.
Rather the ISP....... could just be data from a weak Wi-Fi
ts27330
V6 3.6
Set up a secure VPN connection for the download. Yes, a "Validation Of Checksum failed" error almost always means the file is corrupted, altered, or incomplete. It indicates that the calculated checksum (a unique mathematical signature) of the file does not match the expected original value, meaning the data has changed during download, transfer, or due to storage issues.
crackerjack1957
When he says download......I'm thinking he means trying to read the PCM
That's when he is getting the validation of checksum failed
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Not sure that can be done unless he purchased another license. Most tuners need a fresh license for a different VIN PCM.
One of the main reason I didn't go with HP was the expense for licenses (coupons) of the PCM and TCM. My truck is a peppy grocery getter. If I had a worked 6.4 / hellcat engine in it, that would be another chapter.
If he changes the VIN in the new PCM to what his truck is, then maybe.....
crackerjack1957
One of the main reason I didn't go with HP was the expense for licenses (coupons) of the PCB and TCM. My truck is a peppy grocery getter. If I had a worked 6.4 / hellcat engine in it, that would be another chapter.
You would think HPTuners would have asked for his VIN when they unlocked his PCM.
But I'm a little confused by his statements......does he have his original PCM & removing it an placing the unlocked PCM & trying to read or write???
04fxdwgi
2016 1500 Sport
That's what I did on mine. Bought a used PCM off ebay for $45 and sent it in for the unlock (was a special on sale deal free when I bought the tuner. Got the Trilogy tuner and PCM unlock for $450 shipped). My OEM PCM is sitting on a shelf in the garage.
crackerjack1957
So did they right the VIN to PCM or did you?
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Confused on all the talk about the internet connectivity. Internet has nothing to do with downloading/uploading a file from the PCM into HPTuners or vice versa.
@Bigskyroadglide you ever hear anything back from HPT?
crackerjack1957
If it needs to update definitions before it can read a PCM
How do you think it gets???
And term for VCM suite is read/write
Not download/upload
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Not download/upload
That sounds like a VCM issue, and not a read/write issue. Pretty sure when he said "downloading the stock tune from a fresh unlocked pcm", he was talking about the actual file transfer from the PCM to the laptop, which doesn't require an internet connection.
