Validation of checksum failed
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
VCM editor .... Internet connection is required on the security bypass vehicles
VCM scanner sometimes on the above
I'm done... LoL
Waiting on ops response from feedback from HPTuners
AI agrees with me... LoL
An internet connection is required for initial setup, licensing, and updating the HP Tuners VCM Suite. It is also required for flashing/writing to many newer (2018+) vehicles and, in some cases, to prevent data logging pids from dropping. [1, 2, 3]
Key Requirements & Usage
  • Initial Setup: A stable internet connection is required for the initial installation and device registration.
  • Licensing & Writing: While older vehicles might not require it, many newer models (e.g., 2018+ Dodges, 2017+ Corvettes) require an active internet connection for every "write" or "flash" procedure to verify licensing.
  • Performance Data: An active connection is needed when using the controller unlocker or to prevent issues with logging.
  • Updates: Regular updates to the software (both stable and beta) require internet access. [1, 2, 3, 4, 5, 6]
WorkaroundsIf you are tuning away from Wi-Fi, you may need to use a phone hotspot to maintain the necessary connection for the software to operate correctly. [6]
AI can make mistakes, so double-check responses
[1] https://forum.hptuners.com/showthread.php?p=628306
[2] https://www.youtube.com/watch?v=-cPJMw8Kkfs
[3] https://forum.hptuners.com/showthread.php?82735-VCM-Suite-v4-6-Now-Available
[4] https://support.hptuners.com/suppor...nlocker-web-exception-name-resolution-failure
[5] https://www.hptuners.com/documentation/files/MPVI3/Registering Your MPVI3.htm
[6] https://forum.hptuners.com/showthread.php?111089-Internet-Necessary-to-Write-EVERY-Time
Bigskyroadglide
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Update, still no joy.
Hp Tuners, response
There isn't much to do right now until our engineers get this defined.
With all the new supported vehicles we release monthly, manufacturers update calibrations and OS monthly as well, we need to get it all defined. It takes time and is not simple.
I will reach out for a time frame, but i cannot guarantee it will be resolved quickly.
So, I can read the PCM file, but get a failed checksum. Indication file is unusable.
PCM was purchased used from a salvage yard, sent to the service FRP uses and unlocked and the correct VIN written.
I still have the original stock locked PCM.
From reading the email from HP Tuners. Apparently they have not tuned a 2024 1500 classic and need to have there engineers do something with no definition of a timeline or outcome.
I've already purchased the hp tuners upgraded mpvi4, a $250 upgrade, the 2018 plus bypass cable, for $90 plus overnight shipping total $127 and 6 licenses for $250 and engaged FRP for an unlocked PCM $250 plus 32 for shipping. Total of 282, plus paid FRP for tuning, $450 which they can't deliver until HP tuners resolution of issue.
None of this is FRPs issue. Ryan has done exactly what he said he would do and is as frustrated as I am on this issue but he's at HP Tuners mercy just like I am.
I've switch computers. Internet hosts, read the file and had a failed checksum multiple times. Downloaded hp tuners vcm suite every day and still no joy.
All this points to, in my humble opinion 1 of 3 things.
A corrupt pcm. Ok if that's the case I have already acquired another one.
A software issue with HP Tuners that they have not addressed. Or
Some additional security with the gateway module that has not been addressed with the HP tuners ers cable.
This is a process and I've even called Diablo and their response, we don't at the current time support 2024. Maybe next year.
So, I'm stuck until HP Tuners does what they need to.
The mpvi4 works on my 14, the current version of vcm suite software works on my 14.
Just not on.my 24.
I hope this clears up the questions.
PS, whether I'm reading the stock file or downloading it, it's still saving a copy to the pc. This is the file the vcm suite says have an invalid checksum. I can download/read the transmission file without the engine and the transmission file will download/read and save.
Bigskyroadglide
Bigskyroadglide
Moderator
Thanks for the feedback. Tuning is expensive but the effects far out weigh the costs.
If it just fixes the minor issues the truck does then I'm a happy camper.
Long story short, in for a penny in for a pound. I've spent far more to achieve less.
crackerjack1957
I didn't realize your Ram was that new.....2024
Doesn't show on the phone.
I'm assuming yours is a classic?
HPTuners only listing the etorque as supported for that year
Bigskyroadglide
Bigskyroadglide
Moderator
I have 2, my avatar is my 14 RT, the 24 is a classic and non etorque. Yeah, my mistake, I read through the supported on the HP tuners site but it didn't register the etorque would be different.
The first through the wall always get hammered.
Bigskyroadglide
Bigskyroadglide
Moderator
Update, HP Tuners came through with an engineering fix, but low and behold it fixed the checksum for the engine, but now the software Update they published will not read the transmission.
Before the Update I could read the transmission now, the transmission is not even listed as an option. Go figure.
Perhaps this is the correct way they have updated their software but I'm not certain. I am using g this as a learning moment.
More to come, however I was able to read the engine file. But no joy on transmission
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Geez, sounds like trying to get USB drivers / software to work on Windoze.
Just send them another BUG Report and wait for the next update. For what they charge for the "credits", it would seem they would be all over this.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
So the problem wasn't your internet connection?? Imagine that... lol
Glad they at least got the first issue resolved, even though they created another one!
crackerjack1957
@bigskyroadglide
Would you mind making sure you wifi is turned off on laptop on the next read & write with HPtuners to see if its needed or not.......just some info others may need....I have a 2014 so it doesn't apply to me .
Thanks!!!!
Screenshot 2026-03-27 at 11-46-36 VCM scanner required internet connection to log or i loose p...png
6speed4.7
Winnipeg
Files have been sent. Waiting.........
Curious, did they ever get this solved for you?
Sorry you had to be the Guinea pig with HP tuners
Hopefully when the smoke clears on your project that they are able to formally list the later Classics as supported
