Vararam paper filter
frank1823
Baton Rouge Louisiana
First off let me apologize if this has already been answered but I couldn't find it after searching quite a bit.
I just ordered a Vararam Air Grabber for my 2013 Ram 1500 Hemi.
So my question is, is there a paper filter available for the Vararam? Just plain air filter. Doesn't have to be a performance filter. I dislike oiled filters and I'm adding the Vararam primarily because I want to add a second battery in the stock Cummins 2nd battery location. Secondly I think it looks cool as heck in an old school way. It will definitely help with a tune once I add shorty headers in the very near future. So that's my question. Paper filter to fit the Vararam, anyone?
crazykid1994
I understand not liking oiled filters but the vararam filters are decent as far as I’ve seen. If it was me I would just order the prefilter for it though. That reduces the amount of cleaning you’ll need to do. Also don’t over oil and make sure after oiling you let it sit for 24hrs in a dry place so all the extra oil can drip off and the filter can dry up. I had the s&b with an oiled filter. I swapped out to a stock airbox because I added a snorkel. I don’t mind the oiled filters because they can be washed but I’ve always preferred paper as I know they filter better
frank1823
frank1823
I appreciate the input brother. The process for oiling you just described is the problem I have with oiled filters. Worrying whether I oiled it too much mucking up my intake, throttle body and other stuff is not something I want on my plate. Worrying that I didn't oil it enough and I'm letting dirt into my engine is another thing I don't want. If either of these two things there isn't a way to know it happened that is immediate. You find out later when you find stuff mucked up weeks or months later, or you end up with excessive engine wear due to dirt grinding my cylinder walls. Then the other pain is the oiling process and having to wait for it to dry. I'd ideally like to just open a box and slap in a new paper filter and I'm done. No worrying if I over or under oiled. Maybe not the best performance I can get but I can live with that. If I can't find a paper filter I'll order a prefilter for sure.
Dean2
Near Edmonton
Take the whole thing back, and put the stock filter box and filter back on. It is a far better setup and provides all the air needed unless you have some serious upgrades and a tune on the truck. It also filters WAY better than any oil bath filter.
frank1823
frank1823
Appreciate the opinion Dean. Yes some upgrades forthcoming and others already done. The truck is tuned and will be retuned after header and exhaust install. I'm not adding the Vararam for performance. I'm adding it because I am adding a second battery to run accessories and the 2nd battery bracket mounts where the airbox currently sits. I don't like the oiled filter idea which is the reason for my original post. Surely I'm not the only one that would like to use a Vararam with a plain paper filter.
Dean2
Near Edmonton
Have yopu considered putting the second battery in the box or under the rear seat? rather than in the engine compartment. The cooler operating environment makes batteries last a whole lot longer, plus, size is not limited.
frank1823
frank1823
Yes, I initially was thinking of going that route but ultimately didn't want to lose that storage space. Those storage areas are full of tools and other equipment. I'd have to then figure out where to relocate that stuff, and my Ramboxes are full. Additionally I like the clean look of adding a factory bracket and associated hardware.
Overall the Vararam will solve my issues quite nicely if only I can do something about the oiled filter.
Filter Wear has a sale on their outer socks,that ends today,if you want to order a cover for the filter.The original Vara Rams did come with a paper filter,so you might still be able to find it,if you can track down it's part number.
DGRebel
California
frank1823, did you ever find an option for the paper air filter? I'm in the same boat and have not found anything yet.
DILLIGAF
Canadian Forces
Canada
Just buy an Odyssey H8 and put on a 6.4L alternator. No need to waste money on a 2nd battery.
DGRebel
California
@ Wild one…the link is for an oiled version of the air filter. Similar to the one that comes with the Vararam/K&N. But thanks for the comment
Not sure how you came up with it being an "oiled" filter
I see it listed as a "Dry" "Paper, White, filter"
Manufacturer's Part Number:
VRHEMIFILTER
Part Type:
Air Filter Elements
Product Line:
VaraRam HEMI Under Glass Ram Air Systems Replacement Filters
Summit Racing Part Number:
VRM-VRHEMIFILTER
Air Filter Type:
Dry
Air Filter Style:
Oval
Air Filter Length (in.):
19.75
Air Filter Width (in.):
15.75
Air Filter Height (in.):
2.00
Filter Material:
Paper
Filter Color:
White
Quantity:
Sold individually.
Notes:
Replacement element.
DGRebel
California
Thank you again, Wild one. I called Summit and they told me it was similar to K&N. Maybe their description is wrong on website, maybe the guy answering the phone does not know his product. That’s why I was wondering if an option/s were found. But if all you want is the “You were right”…Sure, you are right.
I’ll keeping looking. Appreciate the help.
Only way you're gonna find out is to buy one,if it's not what they advertise it as,then return it.
Seems simple enough to me :Big Laugh:
Dean2
Near Edmonton
The guy gives you chapter and verse on the paper filter. Your idea of checking it out is to call some teenager at Summit who has probably never seen, let alone installed one of the cold air kits.
Rather than being sarcastic and impolite to someone trying to help, get off your butt, go to the store, and see if it is the right filter or not. Most things auto related aren't solved sitting in front of the computer.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Might want to try this........seems close to the vararam hemi size.
I think all the vararam replacements are washable type not paper but the 6-pack filter may work......no guarantees
https://www.jegs.com/i/Year-One/219/CH81/10002/-1
shopping
