Video: 2004 1500 with whirling sound and driveshaft play
NicksterFL
I have a 2004 Dodge Ram 1500 2wd.
Last week or so has developed a whirling noise that increases with truck speed (not RPMs).
The rear differential looks ok. no play in the pinion yoke, etc.
However, I noticed where the driveshaft comes out of the transfer case there is some slight play. would this be the cause of the noise?
see video:
https://www.youtube.com/watch?v=ZMIMVlWfI_Q
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
Sounds to me like the pinion bearing loose or tight or failing.... My $0.02
N
NicksterFL
I opened the differential and one of the Spider gears had 4 chipped teeth. Pinion and carrier bearings all seem fine. No play.
Would that cause it?
MarkV
Ontario, Canada
Thats intresting.... How big of chips?
N
NicksterFL
not limited slip. Just a 9.25. 12 bolt diff.
I just replaced the spider gears today and will fill with differential fluid tomorrow and do a test drive.
MarkV
Ontario, Canada
I hope that fixed it!!
MarkV
Ontario, Canada
Me too! I miss driving my truck!
I know the feeling!! I had my pinion nut come off on me.... After re setting the diff many times and replacing all the bearings i found out the gears were miss wore....
N
NicksterFL
I've read there is a recall for the pinion nut coming loose on some years. I'd google it.
phorrestphire
