VVT solenoid
Zoran
Carlisle PA
Hi. I need advice. I had problem with my Dodge Ram 1500 5.7 2010. Check engine light was ON and show fault P0014 ,P0016 and P008. After change Camshaft sensor, VVT solenoid and intake manifold gaskets, show fault U 0010 ,P0108, and C121,and Check engine light is still. ON.
Hagar1
Ontario Canada
2012 Ram 1500
The u0010 code is communication lost to the PCM
P0108 is MAP sensor circuit "high" ... is your map wiring plugged in properly? Looks like an open circuit somewhere in that circuit.
