water coming from grab handle
cody mummert
Pa
so i get in the truck this morning and water starts dripping out of the grab handle on the A pillar. the truck was parked nose down on the drive way all night. the grade isnt all that steep. any idea where it is coming from?
Do you have a sunroof? Check the drains inside the sunroof area. It's possible one of the drain tubes could have popped off also
mcaligiuri
2016 ram 1500 express crew cab
third brake light?
cody mummert
cody mummert
Pa
i dont have a sun roof
brake light thats along trip but i will have to check its out
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Where is your Sat antenna located? Depending on location, it could be the culprit. 3rd brake light is a long trip, I agree. Lastly, your rubber trim (long black strip) on top of the roof may be leaking, but doubtful since you show you're a 2017 in your profile.
I am in the process of replacing every single rubber/plastic on my truck, myself being a 2010 owner.
McBroom
Denison Tx
Hemi 6.4L
I’d agree xm antenna or the long black strip on the roof and third could be and just could be the door seals on the cab.
Blue Streak Pearl off-road package
McBroom
Denison Tx
Hemi 6.4L
Wait a min the xm antenna is forward of the A pillar...
cody mummert
cody mummert
Pa
not sure why my profile was showing 2017 but i have a 2015 . and i looked and the black rubber on the roof line above the doors i loose at the rear of the cab where it wraps down toward the window wtf !!!!!!!!!!!!
tincup
DFW, TX
This happened to me about a week ago and the drains from my sunroof were clogged. I see you don't have one, so I'd look at the third brake light and seal on the door. It's a long way from the back, but as someone told me, water travels, especially if you're parked on an incline.
Where the XM sharkfin antenna is depends on where the truck was built. Anything from Mexico (VIN starts with a 3) will have the antenna near the front of the cab(any HD truck and the 1500s). The 1500s built in Warren(VIN starts with 1) will be near the back of the cab.
cody mummert
cody mummert
Pa
so with that seal should i replace or just rtv seal it
H1Chester
This same things happened to me last year. My previous house's driveway had a downslope and I backed in every now and then. There is a TSB for our 3rd brake light. Dealer was aware of third brake light leaks. Last year I told the dealer about it, they did not find any standing water (from what they could see) and replaced the entire light housing and seal. I was worried there was water sitting somewhere in the truck, never had a smell, never saw any water again.
Black W900
Nashville, TN
My buddy had the exact same problem with his '13, it turned out to be a bad weld in the roof seam above and slightly behind the pillar.
RAM dealer body shop couldn't find it...They sent it to a independent body shop that found and repaired it
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
The first time it happened to my truck it was a bad weld over the driver door.
The second and third times it happened it was 3rd brake light seal.
SYKRAMMAN
Banned
Jersey shore
06 Mega
It also happened to my old 02 4.7l, but it turn out to be the top of the windshield. It was coming out from passengers handle bolt holes.
