weak, poor throttle response 6.4 HEMI
Discussion in 'Engine & Performance' started by Reaper26, Apr 16, 2019.
Sponsored By: Moe's Performance
  1. Reaper26
    Reaper26 Senior Member
    33
    133
    Nov 14, 2012
    Ram Year:
    Engine:
    my 15 ram 2500 6.4 about 2 months ago just all the sudden got weak. ive swapped out my k&n filters, a new EGR, the pipe from the EGR had alot of build up two of the holes in the end were almost stopped up so i cleaned it all out, cleaned throttle body. It ran good on the way home that night, felt strong but the next morning back to the same. havent done plugs yet, but will shortly. Nothing has been done to it other than a borla xr-1 and resonator took off at about 20k miles it has 66k now. Im not getting a smell to make me think the cats... Half throttle and full it is still very strong but starting of and re accelerating after slowing down makes it feel like a 4 cyl in that heavy a$$ truck. Any ideas what to check next?
  2. RLJ10X
    RLJ10X Senior Member
    1,043
    540
    Jun 17, 2014
    Southern Indiana
    Ram Year:
    Engine:
    This is a long shot. Most of my replies are long shots.....
    My 14 Wrangler and 13 Mustatang have an adaptive gas petal. The more aggressively you drive the greater the value of Petal input. Think of it as a built in Petal Commander. When I get in the Wrangler, I turn the key on, then hold the gas petal to the floor for a few seconds, let up and repeat. The computer gets a throttle position reading, even tho the vehicle is off, and thinks you're driving aggressively. Viola! Better throttle response.
    Now wether your big ol truck does the same, I doubt. But maybe....
    If you're getting good gas mileage, that means your truck is probably running fine. It the gas Petal trick doesn't work, get a Petal Commander. That'll fulfill your need need for speed.
  3. RoadRamblerNJ
    RoadRamblerNJ Senior Member
    1,399
    1,206
    Aug 26, 2017
    Knoxville, TN
    Ram Year:
    Engine:
    392 Hemi
    More things to try...(more long shots)
    1. Be careful with that "key on, mash the gas pedal" trick. 3 mashes in <10 seconds and you reset your oil life indicator.
    2. Run some Lucas fuel system treatment. Might be partially clogged injector(s).
    3. Put a PC in it and be done with it.
  4. MidwestJ
    MidwestJ Senior Member
    283
    139
    May 15, 2018
    Illinois
    Ram Year:
    2009
    Engine:
    I like these two responses
  5. dexter
    dexter Senior Member
    787
    362
    Jul 2, 2016
    Ram Year:
    2016 Ram 2500 Big Horn
    Engine:
    6.4L
  6. RoadRamblerNJ
    1,399
    1,206
    Aug 26, 2017
    Knoxville, TN
    Ram Year:
    Engine:
    392 Hemi
    You might be right. Maybe use it first. But, at $8. for a bottle (21 gal max), Lucas is the winner. Lucas is $24. a gallon at Wally-World and that treats 400 gallons. Thats roughly 20 applications at 21 gal tank.
    I've used it for almost 2 yrs on this truck and for many years on everything I own. I use it every other tank of gas. I've never had a fuel delivery problem. I'm not trying to sell it, just relate my experience with it.
    Good luck whatever you do.
  7. Reaper26
    33
    133
    Nov 14, 2012
    Ram Year:
    Engine:
    After i put on the EGR and the TB back on i pressed the pedal a few times before i started it and like i said it ran great on the way home then poor the next morning. I read to reset the TB after unplugging it that way, ill try the injector cleaner to see if that helps any.
Share This Page
