weird backing problem
chucky6153
Jacksonville, NC
Ok this is gonna sound weird and its got me stumped. New Ram 2500 with 6.7 Cummins. I tow my boat to boat ramp, back down ramp, unload boat, and go fish for awhile. Come back, back trailer down ramp, load boat, go to back into a parking place and the trailer brakes will lock up. I can drive ten mins down road and it will back up just fine. Get home back boat into garage with no problem. This has happened twice now.
For surge activated trailer brakes:
If you have a five flat plug on the trailer then there could be a problem with the reverse lock out solenoid.
If you have a four flat, the brakes need to be a "free backing" type. You probably need to pull the brakes apart an service them.
For as cheap as entire trailer brake set up are from e-trailer.com you might be farther ahead just to order new assemblies (there are left and right assemblies) and rebuild them.
The reverse is also in a 7 pin round, it's the center pin. I would suspect the reverse lock out solenoid if the trailer has one, it will be on the outlet of the master cylinder.
RamCares
n/a
n/a
Hello chucky6153,
We are certainly sorry to hear about your recent concern. If you're not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please let us know via private message. We would be more than happy to provide you with an additional layer of assistance for that process.
Laura
RamCares
