Elbie
I read several posts from other Ram owners about having a water leak in the backseat. In my case, the wall behind the backseat and even the seat itself is very wet after what was a day of very heavy rain. The driver's side is somewhat wetter than the passenger. All the items I had stored behind the folded down seat are absoluely soaked. In these posts that I read, the 3rd brake light was talked about. I assume that this is the light at the top of the cab above the rear window. In my case there is obvious water behind the plasitc of this light. There is still about 1/2 an inch of water behind the plastic and this is more than 24 hours after the rain. I do have a rear window but it does not seem that that is the scource of the problem. In some of the posts I read, the air vents were mentioned. I do not know what these are??? Could that much water come in through the 3rd brake light? air vents? I am bringing in the truck tomorrow to the dealer for an oil change. Any advice as to what I should insist that they do or not do about this leak? The truck only has 13,000 miles on it. I am so disappointed that this has occurred. I really like my truck.
I do really appreciate being called a "Junior Member". Since I am 73, you other guys and gals must be REALLY old!
