acd118
I installed all LED light bulbs in my 2016 Ram. All rear lights and interior lights work fantastic. The fog lights work fantastic, but my head lights (BOTH Low and High beams) go out sporadically. Also, my front turn signals function properly, but show "signal out" messages and also have the "hyper-flash" inside the cab. The direction indicator lights flash and produce the audible sound twice as fast as the actual turn signal bulbs at the front end of the truck physically flash.
Per the Ram and Dodge forums, I purchased the OBDLink MX+ and also bought the $49.99 AlfaOBD app for the Dodge Ram and installed the app on my Android operated Samsung Galaxy Tab. I turn my trucks ignition to the run position without actually starting the truck. I connected the OBD adapter to the tablet via blue tooth via the start up guide provided in the package. All indicator lights show power to the adapter as well as connectivity. I connected to my vehicle using the Body Computer tab, then to Select Control Unit tab, then MY2016-17 Powernet (with Connection Status showing Connected), and have been able to successfully start procedures for each and every light individually (ie. front left fog light, front right fog light, etc.).
When I start the test, the individual light I am attempting to make compatible with the truck lights up for approximately 10-15 seconds, the tablet shows "procedure in progress", then the light goes off and the tablet shows "procedure complete". I wait approximately five-10 minutes until I started the next light. I have repeated this process several times but still have the sporadic on/off issue with my headlights (both high and low beam).
Am I missing something or doing something incorrectly here? I have scoured the internet and forums trying to find an answer, but have had no luck. I did not receive any instructions outside the quick start guides and see no instructions on the app to follow after the procedure has been completed. I see there are many people with the same issue of no instructions to follow and still having issues after using this product. I sincerely hope that I can receive help with this issue as I have spent my hard earned money on a highly recommended product that was supposed to be simple to use and provide more ability than a dealership.
I have attempted to reach out directly to OBDLink and ScanTool for help. Unfortunately, there is no way to contact them for technical assistance other than another forum. They provide a customer service number to track orders but NOTHING for technical assistance. Then the only response I got back from posting in the forum was to contact the app developer. Not exactly sure why a company uses an app that they don't support but...... Any and all help will be greatly appreciated. Thank you.
