What am I doing wrong?
audio1der
Airdrie, Alberta
Do your wash buckets have grit guards?
Have you considered an air dryer instead of the waffle? The less touching the better IMO.
You could also try a new soap (not syaing anything about whatever product you're using, but not everything works for everyone)
srtpowa
Sacramento, ca
hemi 5.7 w/ 6 speed
So I have a black truck (my first mistake) and it's killing me. Everytime I wash it I notice more and more swirls. I just don't know where they're coming from. I thought I was doing everything right. I do a two bucket wash. Adams shampoo. I rinse it off really well before washing. I dry with a great white waffle weave towel. Then I detail spray using double soft microfibers. I dobt know if it's just me noticing what was there already or it it's more. I find myself looking at every black car or truck I see and I say " Damm I don't want mine to look like that! " I've only had the truck 3 months and at this rate I'll be correcting the paint every year!
Any suggestions? :frustrated:
Only rub your vehicle in a straight front to back motion, never circlular... If you wipe going with the lines of the car then it will be harder for your brain to comprehend the swirls ;)
Andrew09HEMI
Honestly, I will never use anything but a shammy to dry a vehicle to matter the color. HAving owned several dark colored vehicles and can not stand swirls, i found this to give me the best result and I would wax constantly with a liquid wax. Mothers or Megiuars are my favorite, sure there are better products out there but these are easy to apply and remove, give great results and youre not spending $$$ on those nice expensive products.. Try drying with a shammy
Batt4Christ
Clinton, Arkansas
I absolutely LOVE the look of a black vehicle... until I get close to one and am reminded of why I plan to never own one!!!
That being said - keep in mind - 100% of all colors do the same - the difference is - the darker the color, the more those swirls and scratches show. I have owned a dark blue car - and it was nearly impossible to keep looking good - which was the final nail in the coffin for me and dark vehicles.
BUT - as someone else posted - the best action is going to be putting on coats of the best sealer/wax you can. Some are actually pretty good at protecting that paint/clear coat, and when they have enough coats, do a reasonable job at keeping the swirls and scratches to a minimum. I would start with a full correction, de-oil the paint surface (most polishes contain some oils that can hinder a sealer or wax from getting a good bond to the paint). Then seal with something like FK 1000P (Finish Kare 1000P Hi-Temp Paste Wax, high melt polymer car wax, Finish care auto wax). FK is awesome, though not the most gloss for dark colors. It's protection is absolutely awesome. A preliminary coat, followed by at least one follow-up lasts for 6 months - 1 year in my experience.
In-between, when you wash - keep on with the two-bucket method, but check your wash mit for debris. It takes surprisingly little to swirl up dark paint. Of course, pollen is the absolute worst offender.
I like to use Optimum No-Rinse. It doesn't suds up to speak of, but cleans very well - and it actually helps to prevent scratches. I have used it on dark finishes with GREAT success. No Rinse Wash and Shine
I use it for a more "standard" wash - in one bucket with water, I use it as labeled for a "no-rinse" wash, and also mix (according to label directions) to use as a detailing spray/clay bar lube. Stuff is awesome!
