What brand gears do I buy?
Gooseit
Franklin, Tennessee
I am changing ring and piñon and looking at different brands. Motive gears are $255.00 and Yukon are $450.00. Are they that much better? What gears are some of you guys running and what did they cost.
Thanks
Brandon-w
Yukon
2015 Ram 1500
Yukon are some of the best. Depends on your application. If you aren't going performance you can sometimes call a gear shop and get factory takeouts nothing wrong with them for 1/4 the cost.
RamMan381
Do not purchase Yukon! Nitro gear is the way to go.
RamMan381
Had two sets fail on me and they took no responsibility for it even though they knew their product was inferior. There is a massive difference between a 3.90 and a 3.92 gear set. Yukon’s pinion was tiny compared to the Nitro gearset.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Read the fine print! When I redid the Jeep (can't remember the brand that it was), there was a company that if you put 35s on it would basically void the warranty for the fronts. Didn't matter of you had lockers or not.
QwikKota
5.7L
I've had good luck with Yukon's in my Dakota. The Richmond's I took out were very loud in comparison. OEM is a good choice as well.
Sent from my SM-G900V using Tapatalk
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Moes has OEM fairly cheap, but I've used Richmond and would probably use Nitro, Know the guys there, and they make great product!
RLJ10X
Southern Indiana
I bought my 4.10s from Matt at Moe's. They've been perfect.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I used Yukon 4.56 for my build. Haven't tried the others but the installer had zero problems for the rear diff.
Arturo Rojas
