Did they give you a part number for the cover? Do you see a part number stamped on the box at all? If they gave you a part number. Search it to see what pops up. Same with the part number on the box.Had occasion to stop by a dealership this morning so I inquired about it.
Still don't know what it's called, but the plastic cover alone is $79, so I still don't have it.
I imagine it's $2 at a u-pull.
Close.. That box has the fuses and relays for the cabin PTC heaters and glow plugs, it's only found on the Gen4 EcoDieselit looks like an oem auxiliary power distribution block. Something that would tie into the OEM upfitter switches.
Check: www.car-part.comI imagine it's $2 at a u-pull.
If you watched the movie from 1966 with Dustin Hoffman called "The Graduate", you might recollect that, at his home coming/ graduation party, an older fellow admonished him to go into plastics as a lucrative career.Had occasion to stop by a dealership this morning so I inquired about it.
There is no "1st Gen" EcoDiesel, that was the prototype motor that was in R&D for use in Cadillacs overseas. The 2nd Gen motors are in the DS bodies, the 3rd Gen motor is in the DT bodies.From my understanding, 1st Gen Ecodiesels either bit it by 50K or they're still on the road.
Great job tracking it down for the OP. Got to love the folks on here who work hard to help out.Look at these two. The more expensive one (Mopar 68230538AA) is for 2014/2015 and the cheaper one (Mopar 68298467AA) is for 2016 - 2019. They look very similar though so I'm wondering if you could make the cheaper one fit?
That is NOT the TIPM. It is an additional box containing relays etc.The actual name is TIPM, totally integrated power module, sometimes the label is on the under side
