What is this box called?
khigh
Georgia
Hi all.
It's a long, thin relay/fuse box between the battery and firewall on my '15 Lone Star Ecodiesel.
It's pretty obvious what it is and what it does. I need the official name so I can order a cover for it.
Thanks for looking!
K
khigh
Georgia
Had occasion to stop by a dealership this morning so I inquired about it.
Still don't know what it's called, but the plastic cover alone is $79, so I still don't have it.
I imagine it's $2 at a u-pull.
hunterdan
SE PA
2019 classic
Did they give you a part number for the cover? Do you see a part number stamped on the box at all? If they gave you a part number. Search it to see what pops up. Same with the part number on the box.
K
khigh
Georgia
I didn't.
Took about three of them to figure it out, so it wasn't a direct correlation to any numbers stamped on the box.
One guy called out about a 12 digit part number, but I didn't catch it. The guy in front of me said "I never would have found that!"
I'll hold out for a junk part. Kind of a testament to the trucks that neither of the two side-by-side huge junkyards in northeast Atlanta have a single Gen 4 RAM, huh?
hunterdan
SE PA
2019 classic
To me, it looks like an oem auxiliary power distribution block. Something that would tie into the OEM upfitter switches. But I'm having trouble finding the exact block
Close.. That box has the fuses and relays for the cabin PTC heaters and glow plugs, it's only found on the Gen4 EcoDiesel
There doesn't appear to have any useable part numbers on the lid
Sherman Bird
Houston, Texas
If you watched the movie from 1966 with Dustin Hoffman called "The Graduate", you might recollect that, at his home coming/ graduation party, an older fellow admonished him to go into plastics as a lucrative career.
K
khigh
Georgia
Thanks for the replies.
Going to make it tougher to find in a junkyard if it's Ecodiesel specific.
From my understanding, 1st Gen Ecodiesels either bit it by 50K or they're still on the road.
There is no "1st Gen" EcoDiesel, that was the prototype motor that was in R&D for use in Cadillacs overseas. The 2nd Gen motors are in the DS bodies, the 3rd Gen motor is in the DT bodies.
The first model year of the EcoDiesel took the brunt of the failed motors. There's a running of high mileage EcoDiesel that starts at 100K and tops over 400K miles with them still accumulating mileage.
GBs_WARLOCK
Ontario, Canada
Look at these two. The more expensive one (Mopar 68230538AA) is for 2014/2015 and the cheaper one (Mopar 68298467AA) is for 2016 - 2019. They look very similar though so I'm wondering if you could make the cheaper one fit?
K
khigh
Georgia
Wow. That's definitely it. Thanks.
Being unique to two years of the most uncommon engine kind of dashes my hopes of getting a junkyard part.
I'll check pricing and availability. Might try the cheaper one if I get it with fairly hassle free returns.
Thanks again!
Dean2
Near Edmonton
Now that you have the part number just search the wrecker database. Won't take long to figure out if you can find it cheaper. Might also check Rock Auto. Might get lucky.
Dean2
Near Edmonton
Great job tracking it down for the OP. Got to love the folks on here who work hard to help out.
dcathome
Iowa
4.7 Flex
DODGE RAM TIPM TOTALLY INTEGRATED POWER MODULE FUSE BOX
Plenty for sale on eBay or auto sites. They could probably help with the exact part number.
COVER. Power Distribution Center. Top.
DaveSharp
Canada
Just for grins get a flash light and look under the rats nest of cables, boxes and wiring. Chances are it still might be under the hood especially under the battery box.
lat1504
Old Town
V 10
The actual name is TIPM, totally integrated power module, sometimes the label is on the under side
