Possibly?
I can save you the trouble. Their response will be " that's normal, working as designed".Taking to Dodge dealer this week. Will post their response.
And then when it burns up from low fluid they won't cover it because the fluid leak wasn't fixed.Sad but true.I can save you the trouble. Their response will be " that's normal, working as designed".
Not really sure how they can charge you for a filter when it's part of the actual pan assembly. In other words the filter is built into the pan on the 8 speed transmission which is what you have according to the picture you posted. This means there is no (filter) other than the one built into the pan for the dealer to replace. $50 isn't a big deal but it's just another example of dealers charging for things that make no sense. I would suggest asking them why you were charged for a filter when it's part of the actual pan assembly that's actually covered under warranty but that's just me. I have little patience for dealers and their tactics.Took truck to dealer today.
Transmission pan cover has a leak.
They are replacing it along with new gasket, fluid flush, filter, the whole kit and kaboodle.
Covered under powertrain warranty...except a $50 filter. I'm good with that.
