Oil Consumption-Can Anything Be Done?
S
Sean J Blackburn
Update on this. I ran the redline fuel system cleaner and have been running the truck hard! I am just about through a full tank with the redline.
I emailed redline and they said to run 1.5 ounces of cleaner per 10 gallons of gas after the first tank with a full bottle of cleaner is finished.
I've put about 350 miles on since I topped up the oil and filled the tank with redline. No noticeable drop in the oil level yet, but I haven't driven very far.
I'm probably going to drive another thousand miles and see what happens. I usually have to add about a half quart every 1200 miles. That will tell me if the redline did anything.
Also, I installed a mishimoto catch can. I'll probably check that in about 500 miles just to see what is in there.
S
Sean J Blackburn
Just checked the catch can after the first 550 miles with it. Had about 2 tablespoons of oil in it. Have about 800 miles since topping up the oil and it doesn't seem to have dropped any. I don't have a frame of reference but 2 tablespoons in the catch can doesn't seem too bad to me after 550 miles.
S
Sean J Blackburn
Noticed that the oil in my catch can was very, very dark and that oil has only been in the truck for 2k miles since I discovered the oil burn problem. Pretty sure when the oil got so low before I noticed it left some sludge behind.
I did a liqui moli flush and refilled with super tech synthetic. It got dark on me but the plan is to run the truck for a day and drain and refill with Mobil 1 extended performance high mileage tomorrow afternoon. I will run the factory specified 5w20. If I'm still burning at the next change I'll try 5w30.
The reason I'm doing another oil change a day after the first is I don't want any trace of that liqui moli left in the truck, hence the sacrificial super tech that will pick up whatever is left after the initial drain on the old oil with flush.
I seem to be burning significantly less oil after 2 bottles of redline and figured I would run the liqui moli flush in case the oil control rings were sticky etc.,and to clean out any deposits.
So far things seem to be going in the right direction. I'll update again once I've got some more miles on the fresh oil that's going in tomorrow.
S
Sean J Blackburn
Update, the oil burning appears to be as fixed as it's going to get.
I was burning a half quart per 1200 miles. I'm at 1163 miles and the dipstick has moved every so slightly, I mean barely even noticeable. Maybe a 32nd or 64th of an inch.
I checked the catch can, there was a total of 5 tablespoons of oil in 1163 miles. This aligns with the dipstick movement, which is so slight it's almost imperceptible.
I would say the oil burning is pretty much fixed!
For good measure, at my next oil change I'm going to try that new valvoline restore and protect that is supposed to clean up the engine over 4 oil change intervals. But at this point in time the oil burning is essentially resolved.
Thank you to everyone who helped!
For people in the future who come across this thread, what worked for me was running two consecutive bottles of red line fuel system cleaner followed by an engine flush with liqui moli engine flush. And installing a catch can.
S
Sean J Blackburn
Edited to add, also changed the pcv valve
Bam930878
Illinois
With the valvoline restore and protect i would recommend buying a few filters because if your engine is filthy it will clog the filter relatively fast change the filter after 500 miles cut open and inspect repeat as necessary
S
Sean J Blackburn
I'm just about to drain the first fill of restore and protect at 4000 miles. It still looks pretty clean, still a nice golden color. I will cut open the filter when I do the change in a week or two
