Which 2500 Hemi 5.7 or 6.4 ?
Matzram
Crestwood Ky
Ive been looking for a 4th gen 2500 crew cab 4x4 long bed. But it seems all I can find in the long bed models is the 5.7! I’ve found 1-2 with the 6.4, but what’s the deal? Can the 5.7 Hemi move all that weight, or is it just a pipe dream? Or should I just keep looking for the “Holy Grail” of a Long bed with 6.4? Does the 5.7 guzzle gas in the 2500? Can anyone help with this?
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Nothing wrong with the 5.7 in the 2500 if your not going to tow heavy with it.
The 6.4 is purpose built truck engine. Both use a lot of fuel. You moving 7,000 plus pounds. I'd search for a 6.4 powered truck if you can. Good luck
MADDOG
Out Exploring Arizona
I'd agree with @GsRAM. If you are planning on towing much of anything over 7K lbs, get the 6.4L
Ratket
Arizona-
Agree with both above. They both love to guzzle. Also get the larger fuel tank and get the highest numeraical gear set you can I.E 4:10”s.
Docpaulo
6.4... reason 5.7 abounds is nobody is buying it... resale will also be bad
Ramtruck16
Blue Springs Mo
Id like to test drive one with the 6.4 to see how much diffrence in power there is from the 5.7.
Ratket
Arizona-
Not much, prolly wouldn’t even be noticeable. The 6.4”s power just comes on a little earlier and is more constant, more of a “Truck Motor”. The biggest difference
Would be gear selection.
csuder99
The 5.7 trucks are rated at 9000 lbs GVWR while the 6.4 and CTD are rated at 10k. The CTD engine is very heavy so payload is about the same as a 5.7. The 6.4 has roughly 1000 lbs more payload than the other two engine options.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Probably no seat of the pants difference between the two. Also the 6.4 being a purpose built truck engine has stronger internal components. Do a search, I've read some good threads here and one that contained an article that listed all the upgrades the 6.4 has
monteholic
6.4 hemi
I can't agree more about getting the 4.10 gears, the one thing about these 2500's that wouldn't compromise on
Nick@GotExhaust
Preferred Vendor
SC
I also vote 6.4. Its a better built truck motor and the tq comes in earlier, exactly what a truck motor should do.
theviking
If you want to do any internet research on the 6.4 truck motor, it's referred to as the 6.4 BGE (big gas engine).
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
I agree with these guys.
It can be hard to find a specific truck you are looking for especially on the used market, but even new as well. Simply because there are just a lot of options available on trucks. Especially HD’s. And it depends on the region you are in, what the dealer was successfully selling at the time, etc.
Charles williams
Prince albert, sask
6.4l hemi
I've had both and my 16 6.4l feels stronger than the 10 5.7l I sold last fall.the 5.7l was in a megacab (gear ratio unknown)and my 16 is a crew cab with the 4:10s.
2016 ram 2500 crew cab 4x4 6.4l outdoorsman
Ratket
Arizona-
:Big Laugh:Just have Viking bring his by so you can drive it.
