Whine on startup
Steve01990
Alberta Canada
Hey everyone, I need your help.. my 2014 ram with the 5.7 v8 is making a whining sound on startup. I've had the truck 2 years and it always made this sound but goes away after the truck warms up. I rode in another truck and noticed it didn't sound the same so I got concerned.. I have just 1000 kms left of extended warranty and took the truck to the dealership. They're saying it's normal and nothing wrong. What do you guys think?
Here's a clip of a cold start:
LeesEvoX
Houston, TX
Hemi 6.4l
i wanna say either water pump, or fan clutch.
But doesnt the 2014+ truck have the electric fan?
Something doesnt sound right that is for sure.
Oh, have you removed the belt, and given the idler pulley a feel?
Just listening to that noise makes me think its something driven off the belt, because it changes as you rev the engine.
S
Steve01990
Alberta Canada
So I actually just had the water pump fail and they replaced it and said that was the whine but its unchanged
ChevySlayer69
Maine
This isn't normal, probably water pump or oil pump. You could remove the serpentine belt and let it run for 20 seconds (cold) and see if there's no more noise.
So next time you might want to put recording device underneath radiator when you cold start the truck. Even though it isn't "normal", I can see why the dealership said it was in this situation. Bearing or a belt, are any belts frayed at all?
LeesEvoX
Houston, TX
Hemi 6.4l
haha well, that strikes that out.
Can you confirm if your truck has the Electric cooling fan? i cannot remember where that changed in the newer models.
If you have a mechanical fan attached to the water pump pulley. The viscous fan could also be bad.
I would really start with removing the belt, and just giving some of the pulleys a spin.
RamCares
n/a
n/a
Sorry for the trouble, @Steve01990. We kindly recommend following up with our Canadian Customer Care team for further support. You may either call 1-800-361-3700 or submit your info at https://forms.chryslercanada.ca/contact/en/contactCCI.php?brand=dodge to receive an email follow up.
Mark
RamCares
jws123
nj
Yea this is def not normal i would remove the belt and fire it up for a sec to see if noise is gone.
Midknight
New Jersey
Was there ever any resolution to this? I have a similar situation not quite as loud that I've noticed recently. I'm not sure if it's cold weather related or just more pronounced now.
chris52010trx4
ontario
I believe its the ac compressor... up in Canada with the cold weather I find mine does it... my fan clutch is deleted so I know its not that...and water pump seems fine although mine may be a slightly different sound
Sent from my SM-G965W using Tapatalk
cmm47172
2008 Dodge Ram 1500 ST Regular Cab
3.7 L V6
did anyone ever find a fix for this????
Daw14
South Florida
Get or make a stethoscope,check idler,tensioner pulleys and any thing else rotating up front . A dowel rod will do the job.
noraa73
