- Jan 5, 2011
- 12,236
- 26,048
- 2016
- hemi 5.7
TKS syn.
Air filtration is EXTREMELY important to engine longevity. The engineers at FCA, GM, Ferd, etc have designed the air intakes on their vehicles to flow as well as possible while maintaining proper filtration. Fine dust in an engine over time is bad news.
I have the ACDelco equivalent air filter for the 5.7 trucks coming and should be here early next week. I will post some pics and my thoughts on it when I get it. If its a good filter, I'd say run it because its about $10 cheaper than the Mopar filter.
Another thing I'm going to add here, I've 2 different CAIs for this truck, the S&B and the Vararam Air Grabber, and the only one I felt any difference on was the Air Grabber. But after seeing that test that @Burla put in the OP, my stock intake is back on my truck. With one exception: the lower airbox of an Ecodiesel. It takes the same filter as the stock 5.7 air box but the inlet tube is about 50% bigger. Cost me about $60 and its OEM parts. I verified with my Trinity that it flows virtually the same as a Vararam albeit slightly worse. Also it doesn't look as cool.
I won’t buy wiz again either.OEM for me.
I was going to try “Green” but after Cory’s find im going to look for an AC Delco for my 6.4. If i cant find that it will be OEM as i always have.
I got a WIX one time and was not impressed with the construction compared OEM.
GOOD FIND @Hemi395 !!
Sent while firmly grasping my redline lubed RAM [emoji231]
Assuming you have a 2018 HEMI Ram1500, do you happen to know the AC Delco part number by chance...? What did the AC Delco cost you...?Been running an AC Delco air filter in my 2018 for the past 5k miles. So far so good. Fit well and is less expensive than OEM. I don't recall since it's been awhile, but I think the AC Delco was very similar to the OEM when placed side-by-side....wish I had taken a picture.
Me too. AEM filter with factory box is damn good as it is.I run the factory airbox and an AEM Dryflow filter. No warranty voiding changes and ye old butt-dyno says it's peppier that it was with the factory filter.
I considered an aftermarket system like the Varam(sp?) that frees up the airbox area for a 2nd battery, but they have so many issues I decided against it.
-K
Thanks Dawg! Appreciate it!!!Purchased from Rock Auto. PN's below for both air filter and cabin air filter. Think I paid $15 for air filter and $6.5 for cabin filter.
I've been peeking at that. Is it worth the price being that it's just the tube? Also moving the MAF sensor makes me kinda nervous.
Hemi Ram does not have a MAF sensor. They rely on a speed/density system that primarily uses a MAP sensor.
Too much hassle factor for me. Washing, blowing out with air, oiling (what a freaking messy chore)....
I highly doubtful any of that translates to perceptable increases in horse or longevity.
I characterize these chore air filters as a money making scheme, catering to people who aren't engineers and don't do controlled blind studies, but want to feel inside (or brag on the outside) about look-at-what-i-can-do and feel special about themselves while they waste the 27 minutes every quarter doing air chores instead of throwing the ball with the kid or taking a walk with the wife.
