Why is there no block heater indicator
Kc, Mo
3.0 V6 EcoDiesel
I searched the forums and can't find any way to ensure the block heater is working until it's time to start and the temp gauge reads 80. Why isn't there a small indicator on the dash display or anywhere to let you know if it's working when you plug it in?
MADDOG
Out Exploring Arizona
I guess the Ram engineers and designers didn't ask us about that specifically.
It would be nice to have for sure.
Big Terry
Dover OH
I just turn the key and see what the EVIC says. Mine will get up in the 130+ degree range overnight, when temps are in the 30s. Without it, temp stays in the 50s.
I really don't see a need for an indicator, until they actually put a thermostat on the heater. Plug it in when I get home, unplug it when I leave. All I need to know. /shrug
Administrator
I use an Aeotec Smart Switch 5 on my home automation system to control my block heater, it also shows the power consumption. There are WiFi version of this type of smart switch which work stand alone through an app on your phone.
The block heater is not connected to the truck electronics in anyway. Without something that has power meter, watch you coolant temp at start up.
For the EcoDiesel the block heater draws about 420 watts when its on, for you Cummins owners it will be up around 750 watts.
Typetwelve
EcoDiesel 3.0
You know...I wish it did have some display, but it doesn't.
One thing of note, on my display, all it tells me is "<122F" for coolant or engine temp. A few hrs with the heater running, still says the same thing.
Administrator
If I'm not mistaken, the block heater is self regulated to about 100°F. It is an immersion heater in the coolant on the side of the block. Even with mine parked in a garage and running the block heater for 2-3 hours, once the truck starts the coolant temp is about 80°F, oil is >122°F
sbarron
Wasilla, Alaska
Talk about first world problems - here in Alaska we know whether our block heater is working or not when our cars start in the morning.
Seriously though, I don't think in all my years I've ever seen a block heater fail, they are basically like a super low wattage water heater element rather than the circulating pump heaters.. The only reason they would likely fail is if they are run dry and if you have no coolant at the bottom of the block - where the freeze plugs are - you have much bigger problems than a non-functioning block heater. Plenty of bad extension cords or non-functional outlets, but these can be checked with a simple lighted-end extension cord.
gary87xj6
Richland, WA
6.7L I6 Cummins Turbo Diesel
Please excuse my ignorance, first modern diesel, in the 2018 User Guide for my 6.7L it mentions plugging in 2 hours prior to driving. Right now Eastern WA has 12"-16" of snow and low 20's. Based on the post above, I assume it is "OK" to keep it plugged 24-7? Thanks
ErnieBoling
South East Texas
6.7L Cummins
Yup. Keep it plugged in as long as you want. It is self regulated. Sometimes mine is plugged in 8 hours, sometimes 3 days. The plug it in 2 hours is the recommended minimum to allow the heater to have max effect.
TonyMM
2016 RAM 1500 CC 6"4 4X4
What do you mean by self regulated?
Doe it turn off when a maximum temperature is achieved and turns on again when it is below a minimum temperature ?
Administrator
Isn't the block heater a cartridge style that does not go into the coolant?... Goes into a cavity near the starter?
The Hemi block heater is a cartridge style. The EcoD block heater is by the alternator and is threads right into the water jacket.
timpaine1
New york
3.0 l v6 diesel
What do I want to change to protect the engine and transmission? Do I need a block heater? A battery warmer?
Please me guyz and Thanks in advance :)
Administrator
All the EcoD engines have the block heater installed, some just didn't come with the cord. You can buy one from Geno's Garage for about $20. https://www.genosgarage.com/product/eco-diesel-block-heater-cable/winter
The other recommendation for temps below 30°F is a winter front. You want the Mopar 82213959AC or equivalent that has the adjustable flaps. Close the upper ones first and you can close both the lower ones below 0°F. You really have to watch your temps if your hauling or towing anything with the winter front installed.
timpaine1
New york
3.0 l v6 diesel
Hi crash,
Thanks a ton for your feedback and i will take a look on attached link. Hope it will be enough to fulfill my requirement.
