Roberto Mercado
What are normal reading for a wideband. Recently had my cam install
Ah i see thanksThat is a tough question. Your tuner should be able to tell what you want to see at certain times.
You could see anywhere from 9 to 19 depending on what is going on when you are watching the gauge.
Make sure you've researched proper placement of the probe and orientation in the pipe so it doesn't accumulate moisture, and you're getting an accurate reading.
So I'm not the expert on this, but from what I've read you want it about 12-18" from the collector on headers (I'm running ARH LT Catless). I put mine right between the front and rear O2 sensors.
On CATALYTIC CONVERTER equipped vehicles:
Install the oxygen sensor’s **** upstream from the catalytic converter (a **** and plug is included in the LC-1 kit). Any decent muffler or exhaust shop can do this for you. The wide-band oxygen sensor is then installed into the **** to take a reading. (Insert the plug into the **** when not in use).
The **** must be installed in the exhaust pipe at the side or on top, NOT on the bottom of the exhaust pipe.
Best position is between 10:00 and 2:00 position.
Cool. I shamelessly copied it from another website, glad it was useful
