vincentkrol
- Nov 23, 2011
- 1
- 0
- 2003
- magnum 4.7
Hi, my name is Vincent from Netherlands
I want to connect a remote starter from crimestopper rs-4 in my dodge ram crewcab 4.7l magnum year 2003 and would like to know what color wires I need,from the ignition harness.
I still need two colors could someone tell me what the wires are, below I describe the wires that I need.
1 GRAY: 12V ACCESSORY:
Connect to circuit in the vehicle that provides Accessory Power for systems such as HEAT and A/C. Typically, this wire
turns ON with the first position of the key, DROPS OUT WHEN CRANKING, then returns as the engine starts and runs.
(2)
PINK: 12V IGNITION :
Connect to circuit in the vehicle that provides true Ignition Power for systems such as Spark and Fuel. Typically, this wire
turns ON with the second position of the key, STAYS ON WHEN CRANKING, and continues ON as the vehicle runs.
(2)
