WTB Lowering Kit
Status
Not open for further replies.
HemiBabe
DFW
I am wantin to get a lowering kit, it can be new or used... but in good condition of course. Wantin to go with a 2/4 or somethin close to that. Let me know! Thx yall. :)
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
1st option. You can go with springs for the front, but they will tweak your steering and handling geometry. Cheaper.
2nd option. You can go with spindles which will keep your oem steering and handling geometry, and improve it a lil. More expensive.
Either way you'll have to get a flip kit for the rear 4.5 drop. Basically flips the axle on top of the leaf springs, as opposed to under it, as it is now. Also, both ways you'll still want an alignment done after, and new shocks.
McGaughy's
McGaughy's- Air Bag Helper Kits
Ground Force
Ground Force Lowering Suspension Systems - Engineered From The Ground Up
DJM also has some drop lower control arms or something, but I'm not familiar with them. Hope this helps.
adamwilkes14
DJM parts are quality parts...at least from what I know of the S10 parts they offer.
Trupiano
Registered User
6.7L CTD
I will always recommend McGaughy's 2/4.5 Spindle/Flip Kit. Pretty easy to install, keeps everything aligned where it should be, and it's a nice drop! Plus it's what I have and I love it. You can drop it more after that if you so choose to, just by swaping out the rear shackles for smaller ones, and getting drop coils. Usually find the kit for $520-$600.
http://www.mcgaughys.com/air%20dodge_chevy.html
You a 2wd right?
shadow11
Banned
Houston TX
Yep i'm 2wd but I can't swap out my spindles cause I have the SRT brakes
Trupiano
Registered User
6.7L CTD
Ooh that's right. Well you will have to do a coil spring drop then, and still have to flip the back axle. Ground force has one:
Part #: 9930 Front Coils, Rear Flip Kit, Bump Stops, Shocks. Drops it 1.5" in the front/4.3 in the back.
There's other kits and companies out there too. Your looking for coil spring/flip kit drops. Here's one from JDM:
Front lower control arms, and rear flip kit. 02 Dodge Ram 2/4 Drop kit
shadow11
Banned
Houston TX
Sweet man. I'm going to have to decide which kit I want and start saving up for it. Only thing I don't like about those kits is I really don't want the shocks that are included, I want to get some bilsteins
Trupiano
Registered User
6.7L CTD
I bet you can find a kit without them, or call the company and tell them you want the kit without shocks. I would upgrade to billsteins too! Whenever you do, lemme know if you need some help!
Oefootball_70
OLATHE
I have a set of two inch lowering coils that i am picking up next week. Pm me shadow we can work out a package deal for the coils and spears.
OklaHemi
new age hemi
Djm makes drop lower control arms pricey like spindles but maintain a better ride
OklaHemi
new age hemi
Or even better since i have lower springs already caleb you send me your spindles and cAlipers for the low low and buy the delux mcgaughys kit for your truck
shadow11
Banned
Houston TX
Hmmm tough choice but I think ill keep my big brakes :birgits_tiredcoffee
shadow11
Banned
Houston TX
I like it how it sits now. The back is just a little lower than the front so its almost perfectly level.
iceman
Banned
there is one for sale on another forum
Status
