Ricks Ram
- May 1, 2015
- 4,411
- 3,416
- 2014
- Hemi 5.7
No it is definitely better to just scrap those pigtails and have deer guy from M2mods make you the conversion harness. It will give you an extremely clean install and it will look factory. You can also have him make you the correct harness to enable the inverter that's underneath the passenger seat and you can actually have that work as well. You can de pin the power wire that is going into the yellow plug and insert it into your existing plug for now to run power to but that's all I would use out of those harnesses.Another question: the seats came with the yellow connector from the truck side as well. Would it be easier to just splice those onto my existing truck seat harnesses and then lay some wire out for the extra “tails” left over to where they all have to go?
