air conditioner
  1. M
    2008 Dodge ram A/C stopped Working ?!?
    Hey, wondering if anyone knows abouts air conditioning on 2008 dodge ram TRX HEMI. It was working but was a bit inconsistent ice cold to cold enough, then just stopped it was blowing a bit of frost air put vents as well. But my line out of the bottom of my condenser is hot until halfway up my...
  2. 2019LaramieLongho
    Is It Worth Trying to Get Dealership to Fix AC?
    Hey everyone, I have a 2019 Laramie Longhorn - On a couple road trips this summer, I’ve noticed that the cab gets pretty cool, but not cold, no matter what setting it is in. I did some research and saw that there is a TSB out on itOn a couple road trips this summer, I’ve noticed that the cab...
  3. B
    Ignition Switch Issue?
    I have a 2005 Dodge 3500 with the Cummins engine. When I shut the truck off the A/C and, I am assuming, other electronics and other stuff does not shut off. If I don't rock the key back and forth, everything remains on. This has deadened the batteries twice. I can pull the key out, but the...
  4. LeBeast
    Ac compressor wire melted off need name of new part
    Hello guys! Sadly , the wire connected to the air compressor broke off and crumbled. When I bought the car it was connected with tape. I knew I would have to replace it soon . Can anyone please let me know what I have to replace to get my AC to stop only blowing hot air and begin to work...
  5. C
    2017 Dodge Ram A/C issue air drier plug
    My AC is gone on my 2017 Ram 1500 Hemi, found tsb on air drier filter and leaking at the plug. Has anyone replaced this and how difficult is it to do? Can’t find anywhere showing how to do it so came here to ask around.
  6. A
    Air Condition Issue- Works Intermittently - 2003 Dodge Ram 1500 SLT
    Hi folks, I'm the owner of a 2003 Dodge Ram 1500 SLT and I'm having some issues with the air conditioning. Specifically, the air conditioning does work while I'm driving, but when I'm idling, it doesn't blow cold air. This issue started a few months ago, but now that it's summer time - it's...
  7. H
    AIR CONDITIONING ISSUE
    2009 Ram 1500 Laramie with AC issues. -All actuators I can get to immediately behind dash work properly. -Compressor and belts were replaced. - Thermostat was replaced. Here is what is happening after Compressor and Thermostat were replaced. Any idea what could be causing it? AC set on Lo...
  8. 2
    AC issues
    2007 Dodge Ram, 5.7 Hemi - not able to charge AC unit. Checked operation of blower, cleaned condensor, clutch engages on condensor. Using only standard single line with gauge to charge. Gauge goes up when compressor turned off (as it should I believe) but goes to zero when compressor on. ANy...
  9. K
    AC system issue
    07 ram 1500 5.7 4x4 Last summer I replaced the blower motor resistor/relay on the blower motor due to intermittent issues of not activating the AC. About a week ago while driving I realized my AC turned off. Yet it was still in the fan speed 2 position. Fan speed 1 and 2 the AC, heater etc...
  10. W
    Ac stuck on
    my AC is stuck on no matter what I do. I remove the relay in the clutch turns off. I've even swapped relays and it's still stays on when they're plugged in. Turning on the AC and turning off the AC does nothing it only turns on the condenser fan. I can't figure out why it won't respond to the...
  11. Jessica Smith
    Ram 1500 vs Ford F-150 Air-Conditioner Test
    May seem silly, but things like this are a huge deal in the South right now! Spoiler: Ford wins, doh! Something I hadn't thought about before too, is that assuming the AC units are identical, could be a big bonus to the smaller cabs with a regular XLT in white w/ remote start being...
  12. W
    Air Does Not Blow Hot or Cold
    I have a 2013 Ram 4x4. The air started to blow intermittently about a year ago and has stopped all together. I have replaced the resistor and test the blower on a 12 volt battery and the blower worked. Anyone have an answer for this issue?
Carbary
