water leak
  1. S
    RAM1500 2017 HEMI - water leaking by the oil temperature sensor
    Hello, I think I already know the answer what will follow, but did anyone already seen this? Water is leaking by the threads of oil temperature sensor on oil filter housing (oil cooling route). I suspect this part of block is cracked. I don't think this can be repaired without replacing lower...
  2. C
    Rear window, cracked frame, flowable caulk, leaks
  3. C
    RAM 2500 Cabin Exhaust Vent Leak with New Vents
    Hey everyone, I’ve seen a lot of posts on this forum and others discussing the exhaust vents leaking following rain with the old style vents. My 2019 2500 came with the “new” vents. All the solutions I’ve seen have involved replacing the “old” vents with the “new”. I noticed some...
  4. F
    2018 1500 Rear Door Roof Leak
    Bought the truck (18) months ago and had water stains on the roof (can see old marks in photos). Didn't think much of it, was told it was taken care of and i had no issues. Fast forward to this past weekend, you can see the leak is back. Right above the drivers side rear door. I'll be honest...
  5. W
    Interior Roof Water Stains Around Speakers/Phone Mics
    Hi everyone, I just bought this used Ram 2019 Truck for $48K 5 months ago. It had 28K when I bought it. It now has 34K. Powered rear window. No sun roof. I don't have a garage so I park outside. I noticed about 1 month ago that there are water stains around the interior in the back roof at the...
  6. N
    Please Help! Water Leaking into back seat storage.
    Hi, I’m new here, and barely getting acquainted with how these forums work, but I really need your help. I have a 2014 Ram 1500 and I have had the issue of water leaking into my truck, only underneath the back seat. I have put in a different brake light and still the problem persists. Any and...
  7. T
    Water leak at top of rear window
    I have a 2019 Ram 1500 Laramie 41926 miles with a leak just above the back window that is damaging the roof liner above the rear window on the drivers side. My dealership told me it is not covered by the Mopar extended warranty because they consider it a wear item. I don’t use the back window at...
  8. O
    2017 Tradesman Crew Cab water sloshing in rear
    I haven't seen this particular question asked. As the title suggests, I have a sloshing water sound somewhere from the rear of the cab. The rear of the cab is dry. About 2 years ago due to water intrusion, I replace the vents, light on the rear of the cab, the seal, and silicon sealed the light...
  9. C
    Water Damage - Dodge claims no warranty
    Hey everyone, I have a 2018 6.7L crew cab 4x4. purchased brand new in 2017 from Clovis Dodge out of CA. Had a terrible experience buying from them so I ended up taking my truck to the dealership across town (owned by the same company). September 2021 I was deployed and I returned to my vehicle...
  10. C
    3.9L Water Leak-Intake???
    Maybe someone can point me in the right direction as my local shops have no idea on my problem. I have a water leak on my 2001 3.9L it has 82,000 original miles with no major service ever performed that I know of and has been in family for nearly all it’s life. So, I was thinking water pump...
  11. Ryan J
    Leather seat ruined
    I normally keep my back seats folded up. They havent been unfolded in atleast 2 weeks. I unfolded them yesterday and one had a big mark all across it like maybe it got wet. Has anybody else seen anything similar?
  12. captshootnfish
    "A" post leak on drivers side
    well, I've seen a lot of people posting about a leak on th e A-post at thge oh crap handle, I've not yet seen a cause or solution. My truck is a 2013 Ram crew cab, No sunroof, No running lights. when I purchased this new I had the leak but could never quardinate with the "leak guy" at the...
anitamack
