2/4 Bell Tech Crew cab
MitchD
Orlando
Just received my Bell Tech 2/4 kit with street performance shocks, IHR rear no cut brackets and Air lift rear helper bags. My question is......is there anything else I should purchase before I get into this? I’ve seen mention of f150 end links. Any suggestions or recommendations would be appreciated.
I’m also having issues locating any direct replacement aftermarket(energy suspension, etc) polyurethane bushings for anything on the front or rear suspension.
Thanks
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Retain front factory shocks, the SP shocks up front are too soft for that heavy Hemi, lowered my RC 2011 with a BT 2/4, ended up swapping the factory shocks back up front.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Did you have any high speed vibration from the pinion angle changing?
Graygoose
Oklahoma
Convert, for now.
small
No sir, but mine was a RC truck.
hdoggie24
Huntington Beach CA
Im using the 2/4 drop with the nitro drop shocks. Were on it when I got it. So the factory front shocks work better than those too? I've been considering the Viking shocks but man those are expensive
Graygoose
Oklahoma
Convert, for now.
small
yup, the factory rode WAY better!
Ramcharger60
2016 crew cab sport
I wonder what it would be like if I put factory shocks up front and set of Vikings in the rear?
That is the setup I am running now. Will be buying the Vikings for the front soon. I like the adjustability to dial in the ride. The front is not firm enough for me with factory front shocks
Sent from my SM-N960U1 using Tapatalk
6speed4.7
Winnipeg
I absolutely agree
I’ve got the stock shocks up front and single-adjustable Rancho’s on the back
Definitely a smooth ride
Street Performers up front were way more mushy than stock
Previously I had single-adjustable QA1’s, set at 5- front and back- way firmer, performance oriented ride with very little bounce
Prefer the adjustability of the firmer front as well
Depends what the OP is looking for...
H1Chester
Hellwig rear sway bar.
