2013-15 fog lights
1500ram12
5.9L Cummins
I'm in the process of adding factory fogs to my 15 tradesman and I've hit a wall on finding a part number. So dodge decided to make the foglight jumper wiring into 2 pieces. I've got the jumper that goes from foglight to foglight. It's the section that goes from the jumper up to the tipm (or whatever they call it now) the Mopar website doesn't show this section of wiring and the techauthorityonlinedemo.extra.chrysler.com site doesn't show anything either.
So I was hoping that someone with factory fogs could check their truck to see if there is a tag with a p/n on it. And if indeed that section runs from the jumper directly into the tipm.
Sent from my D6708 using Tapatalk
1500ram12
1500ram12
5.9L Cummins
Here is a pic of the connector that it comes from
This is the backside feeding from the truck. Obviously on non foglight equipped truck on the corresponding side is empty.
Pin #23 is white/yellow, left fog
Pin #24 is white/orange, right fog
At first I thought the wiring was there but couldn't find the connector. But turns out that the headlights use the same color wires.
jrockptbo
I have a 2015 ram. It has a factory foglight button but no lights. the button work, door alarm goes off if you leave the lights on. I ordered new headlights that come with a set of fogs. Where do I find the wires under the hood? Or do I need a harness to goto the fuse box?
Duesman
New york
Is there an actual picture of how you guys tapped into the plug?
JB179
Cape Coral
Could you contact me. I have a couple questions and you seem to have mastered this fog light install.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
John,
Please edit/removed the private phone number from your post. (Message sent)
M² Mods.
