2013 Ram 1500 Problems
Ev2013Hemi
Hey all,
I am struggling with my truck.
I started getting ECS errors, changed throttle body, and waiting for a new pedal sensor. But I added new tires and now I have traction control light coming on under acceleration with no slipping, anyone had an issue like this and might be able to suggest a starting point.
Also, would a bad app sensor going bad cause it to bog down. I put in the BBK 90mm throttle body and it doesn’t want to go. If I mash it the traction control light comes on, and it even acts like it has a miss.
Appreciate any thoughts
TheEnder
4.7L V8
Hey all,
What’s your engine and your transmission?
Sent from my Blue Onyx RAM 1500
Tach_tech
5.7L HEMI
What codes are being set?
Ev2013Hemi
Ev2013Hemi
P2127
After I replaced the throttle body, I cleaned and secured the connection to the pedal.
I have not gotten the code again, but still have all the symptoms.
the traction control light is new, as well. but the OBDII isn’t showing any currently.
jabartram
Corpus Christi, Texas
2020 Power Wagon
When i installed my new tires i got the trac light on the highway under acceleration, it stopped happening after i took a 300 mile trip and broke in the tires.
burner71
plano, tx
When I added an oversized ported throttle body I had issues for 2 days of the car going into limp mode. I would shut it off, turn the key on and press the pedal full 3 times and it would run again for awhile. After 2 days it never did it again.
