2013 Subwoofer and custom fiberglass box.
VdubBry
Thanks, yes there isn't a ton of information out there yet, and really a bunch of unanswered and unknowns on this Uconnect system. It could be a very cool system.... if it works properly lol. So far my USB cable for the iphone won't work, unless I need a special cable, not sure? and it shows apps on the Uconnect website like Pandora etc, and I think I finally got them to confirm, they're not available yet.
ramflava
ramflava
Albuquerque, NM
6.7 Cummins Turbo Diesel
Yeah, it's going to take some time I'm sure. I rarely drive my truck and when I do it is for short periods of time, so I'm not to concerned about that stuff yet.
VdubBry
Cool, yeh I figured as much, for me its my daily (for work) and my old truck I had just put in a loaded Pioneer Avic Navi etc. That thing did everything but toast bread lol.
I ordered all my install stuff today so we shall see. Do you have an iphone? I can't seem to get the iphone usb jack thing to work.
ramflava
ramflava
Albuquerque, NM
I do have an iPhone. Mine worked just fine. There are two USB jacks to get the iPhone to work, you gotta plug it into the blue lined USB port that is just the micro SD card slot
VdubBry
Ok cool. That's the jack I was using too. I'm thinking that when you use that port it only plays music stored on the phone not apps like pandora etc.
ramflava
ramflava
Albuquerque, NM
Oh that's what you were trying? Yeah I think it's only stored music.
VdubBry
Thanks yep I figured that out finally lol. For now if you want to use the apps you have to either use Bluetooth or the Aux In port.
I was trying to setup the voice text messaging too, couldn't figure that out, then called them and they said voice text isn't supported on iphone lol. I ordered my Audio Control LC2i with bass control, box, wiring kit etc, can't wait to get the thump back!
VdubBry
Finally got to opening the truck up and the factory amp doesn't seem to be in the same location as where yours is. Now the quest begins!
ramflava
ramflava
Albuquerque, NM
Try same location, but on the passenger side. You may need to pull off the Kickpanel. Only other logically spot is under a seat.
VdubBry
Hmm yeh I looked in the passenger side and there is a very small black box but I'm not sure if that's it, under both seats and rear seats there was nothing. Definitely scratching head now lol.
VdubBry
I forgot to note that the speaker wire colors you gave me a page back are correct I pulled the door speakers etc, I just can not find the amp to tap the wires at, I must be overlooking it!
ramflava
ramflava
Albuquerque, NM
It's probably the small black box. Should have two harnesses (1-white, 1-black) plugged into it.
Gtsum27
Voice text works fine with my iPhone 5 and 2013 8.4an
VdubBry
Ill double check but I think the small black box had 2 yellow plugs in it and I didn't see any wires resembling the colors to the speakers.
VdubBry
Do you know if that signal is full range? My subwoofer doesn't seem to be getting as low of notes as it did in my last truck, but it could also be because the box is .525 cu. ft and my old one was more like .650 cu ft. Would that make a difference?
ramflava
ramflava
Albuquerque, NM
Box volume can make difference. It's an aspect of tuning the sub. Another thing is that you're using the factory head unit.
Are you using a basic LOC or does it have controls. Check the amp settings for gain and such.
VdubBry
I think it's the factory head unit issue for one, and yes I have that AudioControl LOC that has a ton of controls, I need to read on level matching or something to see what I should set the amp gains at and then set the levels on the LOC.
I also mounted a subwoofer volume control knob in the center console area so have that to adjust as well lol.
Da_Beast
Nice work
Awesome work... This is exactly what I want to do to my 1500 but I have never worked with fiberglass... Oh and I'm absolutely going to steal the wiring scheme for sure... If you ever wanna fabricate a couple of enclosures me just let me know how much $$$
