2014 RAM 1500 Express Crew Cab
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Ok great I was just trying to help if I could. I do have a question that you can possibly help me out with My rear setup that I’ve put bought so far for the rear of my 2012 crew cab is the bilstein 24-187374, the 140 springs, a set of a carli adjustable track bar links, carli track bar drop bracket, a spohn adjustable track bar, and the metal cloak bump stop pads. My question is do you suggest that I should get the bilstein 33-185569 shocks for the rear or do you think the ones that I already have will be good?
No problem at all.
The 24-187374 are the the 0-1" 5100's. they'll be good for say 1" rear springs or spacers.
The 33-185569 are Bilstein 5125's that have the proper lenght to run the SLF-140 springs, 29.7" extended, 17.91 compressed. They're like super loooong shocks and it's what Mopar added for the rear with those springs. i'll run those instead.
Just remember those shocks will only work with those SLF-140 springs, or if you needed more spring later on then you can add Clayton 2.5" coil springs (Part# COR-1510251), which also have the lenght needed to run those extra long shocks. I run the Claytons in my truck with extra 500lbs in the bed. Without that weight your truck butt will go 2.5" for sure.
Have fun.
Jason Boulware
Rock Hill
No problem at all.
Have fun.
Thanks I appreciate your help I ordered a set of the Looonger shocks today. Thanks again
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Got my Purple Cranium diff guard in the garage.
50771666743_588c7ddc44_k.jpg2020-12-28_12-53-10 by RAM RSM, on Flickr
Waiting for a lubelocker gasket i ordered that should be here tonight, then to pick a day that is not darn cold to change the fluids and add this thing back there :)
50771668993_f205131a16_k.jpg2020-12-28_12-53-51 by RAM RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
No plans with getting a Dif Cover ? Those AFE ones look nice
We don't have steel options, only aluminum and they're huge. i looked everyhwere for a steel version like we have in the Jeep world and couldn't find anything other than the diff skid above. That'll do in my case.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Removed the rear diff cover this afternoon, cleaned everything down there, added a lubelocker gasket and put the cover back, torqued the bolts at 20 ft/lbs
50777810962_daa9218bb6_k.jpg2020-12-29_07-00-34 by RAM RSM, on Flickr
50777701076_a6026896d0_k.jpg2020-12-29_07-00-42 by RAM RSM, on Flickr
This is the torque sequence i used for the cover, Ty lubelocker
50777701376_19e905e04a_k.jpg2020-12-29_07-00-49 by RAM RSM, on Flickr
I'll get some pics with the rear diff tomorrow, the wind was blowing like crazy and it was dark already when i finished. Nothing special just a dirty diff cover with the guard on. I thought about painting the cover with black rustoleoum but because of the dam wind this evenning i didnt have enough time for cosmetics and she'll get dirty again in a couple of days anyways :)
Hoping to do transfer case and front diff tomorrow afternoon after work. Hopefully the wind will calm down.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
What is it made of? I am planning on getting a diff guard and modding it by adding either a skull or something else to it ...
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
It's a steel piece mig welded and powercoated with the good stuff. They have different colors and textures. I wanted the one at no extra cost and that one happens to match the sway bar. :)
2018 2wd
I might be able to use that then to attach a damn skull or something else around it lol ..
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Placed my upgrade from HPTuners MPVI Pro to MPV2 Pro. I bought that interface back in 2006 and have seen a nice share of vehicles throughout its years. Already paid for itself so many times ago it's only fair to upgrade the darn thing after 14 years of service :)
2018 2wd
15 min later
Hi beams on, fog lights on
Untitled by RAM RSM, on Flickr
Hi beams + fogs + lightbar
I'll wait for the sunset to adjust the fogs and see how they look at night.
So question ... if doing the hi beams with fogs on with ALFAOBD and then you set your highs or fogs to be your DRLs , do both go on as your DRLs?
I want to set my HIGHs as DRLs to see if both the highs and fogs stay on ... is this possible ?
crazykid1994
As far as I know no. It’ll only turn on the light selected for DRL. The fog light with high beam just sets the vehicle up so at night if you are using your fog lights and switch on the high beams it won’t disable the fog lights.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I dont know that we can pick which ligths are the DRLs though assuming you can choose the Highs as DRL you can set the fog on with hi beams, then the fogs will have to be on first for they to stay on with the hi beams.
As Crazykid indicated the fog on with hi beam setting is just to prevent the fogs from turning off when the hi beams are on.
2018 2wd
I would check the wattage of the led pods before doing 4. A 9006 bulb is 55 watts. The led pods I have installed come in 2 wattages. The ones I’m running are 35 watts. The other style are 14.5 watts.
Ok sorry @ram1500rsm but back to this post ... will 4 pods at 12-watt, 1080 lumen spot/flood combo beam be ok ?
