2015 1500 5.7 Hemi..... p0308 & p2099
Lifted2wd
Lifted2wd
Finally got the truck back. All lifters failed. Including the once I had replaced a year ago. And the cam shaft was destroyed
PoMansRam
East Aurora NY
He said the lifters were damaged but couldn't explain the cam
I don't think there's a scenario on a hemi where bad lifters won't damage the cam over time.
Was that really wallowed out cam lobe your problematic cylinder?
Just curious what oil change interval you followed and what weight oil you used.
Lifted2wd
Lifted2wd
No that's the crazy part it wasn't the misfiring cylinder. I did 5k with deal recommended. From now on I'll be following the oil recommendations from the forum
PoMansRam
East Aurora NY
That is something that that really hogged out lobe wasn't even the suspect cylinder!!
I do 5000 mile OCI's with my 2019 classic hemi and use synthetic 5w30 if that makes a difference I dunno. I also add a bottle of MoS2 or Lubeguard biotech if I'm feeling so inclined. Again.. no idea if that's going to do anything at all that's beneficial.
I also have a filter cutter and examine every used oil filter. I'd like to think I'd see glitter if some metal hogging madness was going on.
Lifted2wd
Lifted2wd
Thanks for the info! Ya going to use Lucas additive at each oil change. I had the oil changed 200 miles ago and nothing in it. Which was even more bizarre.
On the cam #8 which was the problem cylinder barely showed wear
RedSRT4Me
Scottsdale, Az
2015 CC Sport
This is what I've used in my truck since around 58,000 miles. Truck has 115,000 nowScreenshot_20210806-073141_Amazon Shopping.jpg
broken arrow
pittsburgh pa
sorry to chime in here but having same type of issue on a 2012 5.7 but misfire on 5 havent swapped injectors yet but you said an o2 can cause an isolated misfire ?
Ronsterritory
