2015 2500 Cat Back Exhaust
ngkdum
San Diego
Aside from Flowmaster, does anybody make a bolt on cat back exhaust for a 2015 2500 SLT Crew 5.7L. I haven't been able to find anything in my searches. Also, if not for that truck would an exhaust kit for a 1500 5.7L of the same year work? I know that the pipe diameters are the same.
Thanks in advance
BradMitch
Delaware
Interested in knowing as well. I have a 2017 2500 and it seems like all of the systems are for the 1500. I believe it will work.
Nick@GotExhaust
Supporting Vendor
SC
Which engine do you have? I am sure we have several options. Message me with your vehicle info, including cab size, bed length, and engine. I can provide some recommendations and we can quote you on a system
Brian2081
Weatland Michigan
I am in the process of gathering a stock "16" exhaust. Already have the factory 3 inch single in with 2 1/4 dual out muffler. Need pipes tips and 2 factory hangars for the left pipe.
hoohah52
WI
2007 2500HD 4x4 RCLB
Thanks in advance
I went through the same situation with my 07 2500 long bed 5.7. Wanted to upgrade to a stainless Magnaflow cat back dual exhaust and all listings were for 1500 5.7's with the "does not fit 2500's" warning even though the pics, specs and hanger locations appeared to be same as on my 2500. Ended up purchasing it. Fit like a glove! Even came with extra extensions for long bed/crew/quad cab frames. Mines a 3rd Gen but the same approach with a little research may apply to a 4th Gen 5.7 Hemi. Or go custom like the gentleman above suggested.
