For a little clarification for those people who are afraid of the 8 speed simply because of the rotary shifter.
The rotary shifter is just a switch, that works no differently from a headlight switch or an AC control knob. That switch sends a signal to the TCM, which then (if conditions are met, eg not moving when trying to shift unto park) sends the signal to an electronic actuator connected to a cable, that is connected to the transmission range selector lever. The actuator works much in the same way as the actuator on the transfer case in 4wd models. When the signal is received, it moves the cable and completes a change of range.
There is no fancy actuator inside the transmission that changes range, there is just an electronic motor on the outside, that still uses a cable, just like in column shift trucks. The difference now is that the TCM can intervene with you trying to slam the truck from reverse to drive while you're stI'll rolling backwards, or from accidentally shifting into park whIle you're rolling. It prevents damage to the trans.
The technology is nothing new. It's seriously the exact same system used to shift the transfer case on 4wd trucks (the same one that's been in use since the 90s), just applied to the transmission now.
