Yes it goes around, almost like a c clip. I'll try a screw driver. it almost has like teeth on the ends so at first I was trying to pinch it but maybe I need to spread it and then pry it upUsually clips like that slide up, in the last picture does the white clip go all the way across? If so there should be a way to pry that up.
Put the red piece back on,but only to the first stop,squeeze it's sides so it grabs the first step of the white connector,then push the red connector on farther to release the white connectorYes it goes around, almost like a c clip. I'll try a screw driver. it almost has like teeth on the ends so at first I was trying to pinch it but maybe I need to spread it and then pry it up
Yeah I would have to agree. Hopefully this thread helps someone in the future who is an amateur mechanic at best just trying to save some money.Yea, you should be able to figure out how a connector works by feel. You shouldn't need a flashlight, mirror anda borescope to analyze a connector to figuure out what the 3 latches do and they work.
Whoever at Chrysler is in charge of electrical connectors, you need to watch this video! You are the reason there are some many zip ties holding connectors onto parts:
Never Go Full Retard
You just went full retard-Extracted this clip from the movie Tropic Thunder (2008). Monologue: By Robert Downey Jr. as Kirk Lazarus.. Referring to when an ac...youtu.be
