2018 Ram 1500 UConnect Touchscreen ‘melting’
roselaneess
Edgewood, WA
2013 and 2018
Cummins and EcoDiesel
Hello - Hoping to get some help! Our 2018 Ram 1500 had ~45K miles our UConnect screen looks like it is melting behind the touchscreen. It is affecting the way the radio works as well as the navigation. Has anyone been able to get their dealer to repair this or is there a recall on this? It apppears this is a known issue that Ram should own up to. Apart from the sealer has anyone replaced the screen?
Thanks!
Fast69Mopar
Thanks!
It sounds like you are experiencing touch screen delamination. The screen and the radio are only covered under the 3/36 Basic Warranty and any radio or electronics would only be covered under a Mopar extended service contract or even an aftermarket warranty like the GE Warranty.
It stinks to have issues after the 3/36 Basic Warranty expires but those are the joys of vehicle ownership. Do some research on here and around the web and you will find some good info about screen replacements.
mtnrider
Georgia
Screen is delaminating, was a big issue with the 2018's. You can replace the screen if you are handy with working on electronics, just google it.
wallacemf
2500 4x4 Hemi 6.4
You might try sending a PM to RamCares on this forum, you may be able to get some goodwill. I have a 2018 2500 and had the same issue a couple years back.
RamCares opened a case and and passed it off to the Uconnect team, I managed to get it replaced at no cost. They know these screens are defective.
You have nothing to lose by trying….
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
If you run out of the other options, here's some Diy info...
Get a new (LA084X01 SL03, one I've used from OeAutoTronics) Screen/Digitizer assembly (definitely not an SL01 version… SL02 maybe) ~ $200 -$300 and replace it yourself…. Or send it off to United Radio, next to the Panasonic plant (Peachtree GA) or NavRepair (FL)
DavicArm_0 (C&H Car Stereo) is reputable << VIDEO >> How to Fix Delaminating OR Bubbles 8.4" U-connect VP3 VP4 LCD MONITOR Touch-Screen Radio Navigation
Reference’s to help
(see SitKneelBend’s info on the forum where you can find it)
>> SitKneelBend is a great resource for help replacing the screen and gave me pointers.
How To: Install a 2018 4C (UAQ/UAS) Radio POST 3051
>> He recommends replacing the original Thermal Pads while you’re in there, I did (Arctic Thermal Pad 145 x 145 x 1.5 mm - Silicone Based Thermal Pad).
>>> Some of my posts 8.4 Uconnect touch screen delaminating Post 209 and Post 223 about it.
Also recommend this...
Amazon.com: 2X BROTECT Matte Screen Protector for Uconnect 8.4 (Ram 1500/2500 / 3500 / Chassis Cab), Matte, Anti-Glare, Anti-Scratch: GPS & Navigation
www.amazon.com
Other Info
RamForum - UAQ/UAS Digitizer Replacement Steps
YouTube - 2017 2018 HOW TO REPLACE Replacement 8.4" Uconnect 4C UAQ LCD MONITOR Touch-Screen Radio Navigation
You Tube – (Factory Radio Parts) - How to disassemble and repair the Uconnect 4 & 4C 8.4 Inch Touchscreen UAS & UAQ Panasonic Radio
