Lee2019Ram
Are they same as 2018 4th gen tailights
To add to what crash68 said, the HD tails will fit in the 4th gens, but the wiring and BCM configuration is different. The new tail lights have separated lighting, so the the turn signals are separate from the brake lights, and have the extra turn signal wires coming from the BCM.Are they same as 2018 4th gen tailights
It’s pretty easy. Add the missing turn signal wires from the BCM, and use AlfaOBD- https://www.ramforum.com/threads/2019-hd-tail-lights-in-a-4th-gen.151018/I already knew that those newer tail lights had separate brake lights from the turn signal lights but if you was to get a set of those and put them in a fourth GEN truck that had the tail lights where the turn signals and the brake lights were on the same circuit, how do you hook those up if there’s not a separate, more than likely brake light wire coming to its own spot in the existing tail light harness?
You could do that, too, with the curt trailer module, but you’d also have to stack a switchback module on top of that so the brake light will drop out when the turn signal is used. Retroshop offers a kit for it, but it’s crazy expensive.Oh, it involves running a whole new wire and that Alpha OBD thing, huh?.....hmm. I was hoping maybe there was an adapter or something that you could buy that would separate the two signals right there at the tail light just like how- I don’t know if you still can or not but way back in the day I saw a trailer wiring kit for like if you were going to hook up trailer lights to a vehicle that already had the separate brake lights from the turn signals, it came with a little adapter module thing that somehow combined the two circuits into one wire so that the trailer lights would work properly being that most passenger vehicle trailers are wired just the same way as most cars where the brake light and the turn signal lights share the same wire.
