2022 Laramie
Tucdog
Cocoa Florida
ECO diesel
Have the above w 20” ram wheels. What is max width for new tires. Also, recommendations on A/T tires? Want a good profile but don’t want road noise or impact/major impact on mileage. Just put in K&N air filter and gained 2 mpg. (4wd ecodiesel). Was leaning toward Toyos.
Also, about to get fuel filter replaced, should I run any cleaner prior to or after? Any diesel additives I should be adding regularly? Live in warm and lovely Cocoa Florida.
Thanks!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
About the biggest tire that will fit without raising the suspension is a 285/65-R20 tire. It has a diameter of 34.59 inches, a width of 11.22 inches, and a sidewall height of 7.29 inches. You can use a tire size calculator to compare different tire sizes.
Be aware if you are putting these on stock wheels you should check inside clearance to make 100% certain they do not rub upper control arms as not all Ram's are created equal.
If you use aftermarket wheels with a different offset this might not be an issue, but could create areas where there could be different contact points
G/T jonny
California
Hemi eTorque 5.7
When I had a GM glow plug diesel I like to use the red line “diesel fuel catalyst’ product. It made cold start way easier and eliminated exhaust smoke. I just went to the red line site. It looks like they renamed it “Diesel fuel additive”
