2024 2500/3500 6.7 Cummins good bad
RamHondo
Wildwood Florida
Anyone having issues ? Engine /Trannie good?
May take the plunge on 2024 need for pulling 10000 trailer and horses, lol!
Currently 2007 is fine but single cab.
Plus nice to have a backup truck!
I can get vendor price thru the company I work for in FL.
Looking for crew cab of course
JayLeonard
6.7 L Cummins
I have a 2021 with 51 k miles on it, close to 20 k miles towing a 7000 lb TT. Never an issue, don’t think another 3 k would change much. Been all over the country never seems to break a sweat so to speak.
Good luck!
zrock
canada
Cummins has not had a good engine since the introduction of DEF. As long as your working it and not sitting around idling you should be OK
The 6.7 was pretty much the same from 2007-'18, not many issues with the engine itself. The emissions system has had its ups and downs, if I remember correctly the first few years of DEF there was issues with the SCR itself and that was recalled/replaced. It wasn't till the 2019 Cummins (new CGI block) you started hearing about engine failures.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
What “engine failures” are you hearing/posting about?
I have had my ‘24 Ram 2500 w/6.7 CTD six months only, and it Tows beautifully and I’m having zero problems even when temps dropped to 15F. Love this engine! (and I was not previously a diesel-fan at all.)
Surprisingly read about a several of engines collapsed lifters and even one that lower rotating assembly punched a hole in the block. They were ultra low mileage engines, and probably fall way under the 1% threshold so nothing out of the ordinary for a mass produced engine.
tjfdesmo
AZ
Pre-DEF 6.7 emissions were more troublesome. It was all EGR all the time and more problems with fuel dilution. DEF allowed them to put some timing back in it, and turn up the wick some.
