2WD 35s
tumulte
4.7L V8
So I was originally planning on putting the 7" CST lift with a 3" BL and running 37's, but now i'm considering 35's instead. The 4" CST says it's for 33's. So basically i'm wondering what the cheapest/easiest way to put 35's on the truck is. It's a 2wd non hemi. I don't plan on taking it off road or anything. I also don't want it to look too stuffed.
I'm planning on 35x12.50R18 Toyo M/Ts. So what do you guys think?
Thanks!
WhiteExpress
Midland, TX
I see no way you can't fit 35s with the 4" lift.
I laugh that it specs out 33s for the 4" lift, since that's what they roll stock!
I plan on 34s w/o lift or maybe the 1.5" coil spacer.
ramin44s
4.7 v8
4" CST spindles and 2" spacer or just run the full 7" lift and you will be fine 90% of the price of the lift is the spindles anyways so might as well
Kevn
Cranbrook, BC
On my 03 I did the 3-1/2" spindles and 1-1/2" spacer and 35's fit perfectly
tumulte
tumulte
4.7L V8
Thanks for the quick replies. I'll have to do some thinking about what I want. I already bought the 7" with 3" BL and shocks for 1800 but I was thinking about returning it. The 4" is like 400 less so I dunno. I don't really understand how 4" could only fit 33's either, but I don't know anything about all of this :) I have a couple of months to decide so we will see!
Thanks again!
tumulte
tumulte
4.7L V8
Oh one more thing. What do you guys think about the Readlift 2.25" lift/level. From what I see they say you can fit 35's on that.
ARam15
Florida Panhandle
I have the 2.5" ready lift level/lift and 35s and they fit great no rubbing
carcandy
South Florida
2018 Big Horn cc 4x4
6.7 CTD
I'm running 35's on basically your same truck 2011 2wd 4.7 I have basically the same thing as the ready lift. 2.5" in the front and 1" in the rear. and I also did the 1.25 Rough Country Body lift. I have no issues with this setup at all. No rubbing the 4.7 turns the 35's just fine even with 3:55 gears.
ARam15
Florida Panhandle
I have the ready lift 2.5 "level/lift and 35"s and they fit great and no rubbing
