3500 DRW or SRW?
Beltsand
SD
N/A (prior 2010,2019,2022)
Cummins
Thank you all for the replies. Still torn but some good thoughts here. I definitely am going to lock in which trailer I want specifically before I buy the truck. The one I was looking very closely at is 16k dry weight, not GVWR. However, having towed my travel trailer all over and visited my share of campgrounds, I get what you all are saying about length possibly being a problem. Here's the issue for me. I'm planning on living in it and as such, one of the requirements is that it has a built-in office for me since I will be there most of the time. I can't find an under 40' 5th wheel with that setup. At least not one that I think would work for a full-time live-in situation. Choices, choices. I think I need to just drive a dually to see how it feels when parking and around town.
Not sure which trailer you are looking at, but I just bought a 41' 5th wheel that has a dry weight around 13k, GVWR of 16,900, and comes with a office and built in desk. It has been working pretty great for me. Montana 3855BR. There is a Montana High Country with a very similar plan that we looked at as well, 384BR or 385BR I think.
Bearcatrp
All my 3500’s I have had in the past were duallies. Love a dually. But this time I went single. Have no regrets. They both have their pluses and minuses. My current 5th wheel is around 13000 lbs loaded. Since most of my pulling are on flat lands, have no issues. But if you’re planning allot of mountain pulling, more rubber on the ground may benefit your stopping. Have talked to folks using a 1 ton dually pulling monster RV’s like the one you’re considering and all state their RV pushes them down the hill pretty bad. Exhaust brake will help reduce the push but if you have to lock it up for an emergency, I would want a dually with more rubber on the ground. Since you haven’t purchased a truck yet, have you considered a 4500/5500? Or, maybe a drivable RV pulling a toad. Allot of possibilities depending on your wallet. Good luck on your decision.
J
JoshsRam
Lake Forest, CA
5.7L
To answer your question, no have not considered a 4500 or 5500. I would think the 3500 would be enough for what I'm trying to pull. Definitely not wanting a drivable RV because I don't want to have to pull a car with me everywhere I go. It's nice to detach the truck from the trailer and be able to go anywhere. I honestly don't know where I'll be going yet. Planning on traveling everywhere I can go and working from the trailer for 3-4 months at a time and then up and moving to a new location.
JerryETX
Elgin, TX
Hemi 6.4- 3:73- 6 Speed
Some 450's do not have any more payload than a 350. I've seen a side by side comparison between a F350 and F450 DRW trucks and both had the same leaf springs, same engine, same rear axle, and same interior package. About the only difference was the front end was beefier on the 450 and yet the 450 has LESS payload than the 350 did by just a few pounds. In some cases a 450 can give you more payload but it's not automatic. Lots of folks have made that unfortunate assumption. Agree you don't need a 450 for that rig. The downhill stopping advice with a DRW is also something I've heard from others on this forum.
jrrector
Montgomery, TX
6.7 Cummins SO
I can relate to your struggle. Earlier this year we took delivery of a 5th-wheel with 16,800 GCWR. We really wanted a SRW for all the reasons mentioned here. In the end, having had too much trailer for the truck in the past we decided on leaving plenty of buffer in the weights and capabilities and got a DRW. We've not been sorry at all. We full-time in the 5er and travel around the country mostly staying ahead of extreme temperatures and typically settle down in AZ for about 4 months in the winter. Probably 8000-9000 miles of towing. Having that extra stability has been a game changer, especially in the mid-west in strong crosswinds. That's our experience and I won't tell you what your best situation will be. That said my 5' wife drives that dually like a boss! :cool: There's a great spreadsheet at this link to help calculate the numbers. GVWR & Payload Calc.
TomAce
Dallas, TX
6.7L I6 Cummins HO Turbo Diesel
There are SRW options out there that will give you what you need. I had the same dilemma (same situation)...looking to upgrade from a travel trailer to a 5er, with a dry weight of about 15k lbs. I ended up ordering a 3500 SRW 4x4, Limited Megacab, with the Aisin transmission, auto-leveling, air ride suspension...Tow capacity is close to 30k lbs, with a payload of close to 5k lbs. In the screenshot, I have the one in the middle.
tourqued
Cross roads
5.9 diesel
We can all say this in a myriad of ways, but once you go "dually" you will never go back.
After owning about 10 semi trucks with the options of "super singles" I will take the duals for the myriad of reasons.
You can run on a flat to a safe space, the load will follow better, you have a very stable platform.
No I dont need a dually to be kool, but to be usefull.
No one ever wished for a smaller truck when the going got ruff.
TomAce
Dallas, TX
Ram's website is a little screwy when looking at payload and towing. I could be wrong but that center one has the numbers for the DRW. the SRW option is the on on the far left.
Yes, my bad. Here is what I actually have. Payload of 4130 lbs, and Max Trailer of 24,070 lbs. In that chart below, anything with a GVWR of 13,500 and above is a DRW:
mtnrider
Georgia
Your actually going to be lower then those numbers, especially in the payload. That chart is best case numbers on a slt. Every option on your limited will take away from that (a lot more then you think)
Dusty
Rochester, New York
Kicking around the idea of buying a 3500 for pulling a 5th wheel that I am thinking about living out of and working remotely. Question for those who have DRW or SRW 3500. What would be the recommendation for this type of setup? I have my eye on a 5th wheel that is sitting right about 16k lbs dry. Most of the SRW 3500s I've seen have a pull limit of around 20k lbs with about 4k-5k of payload which seems a little light for what I'm trying to do. I haven't seen any DRWs on any dealers sites to pull the VIN yet but I would imagine that it would be higher for both payload and overall weight. I would prefer SRW if possible just because it's going to be enough of a pain to park it in places when I'm driving it around without having to deal with the width of dual rears.
My son just had to deal with an inside tire problem on his motor home. Just to let you know that I did not teach my son to use such ****** language while pulling off those tires!
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 80656 miles
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Regards,
Dusty
With my truck camper I'm always changing the rear pressure between having the camper loaded and off. While I gotten pretty good with the counts for air up/down time I sure miss being able to just throw on a Staun Deflater to drop down to my unloaded pressures.
Personally had I not needed the GVW of the DRW I wouldn't have one. I miss the how easy it was to upgrade to a larger tire and rim for off road use, the ease of doing tire rotations, the ease of air up/down, etc. I also dislike that the dually brackets on the camper require the camper to be pushed back 2 inches so the back doors can open without having to flip out the jacks.
Ratman6161
Buffalo, MN
Right, don't trust the chart! Get the VIN number and plug it in here: https://www.ramtrucks.com/towing/towing-guide.html#/landing/bytowing . This will give the numbers for the specific truck in question. I used this a lot when I was shopping because most dealers seem to provide the VIN number in the listings on their web sites. When I got to the dealership to look at the truck I was interested in, the first thing I did was to open the door and look at the sticker to confirm it was the same as I got from Ram's look up tool. On the 2500's in particular its amazing how much variation there can be. My 6.4L Bighorn has a payload of 2974 but an identical truck with the diesel is only about 2200. There are some configurations like a Limited, Megacab, diesel that actually had less payload than the Sierra 1500 I was trading in.
smittyd174
Halifax
Just traded my 2016 Ram 3500 srw . It was a daily driver and towed my 14500 lb 5th wheel with no issues . Drw are more stable for heavy loads but not great for city driving , not that the srw are great , but it will fit most drive thrus. The other issue with drw is servicing , replacing brakes and rotors . Srw just like most cars , pull the tire and and unbolt calipers and mounts , pull the rotor off . Drw are a different animal, there's an a spacer on the front that can be a pain and on the back you have to pull the axles .
You have 6 tires to deal with , but the choice is yours , what meets your needs and where you drive . Just don't buy a 1500 and say air bags and heavier tires .LOL
erictomlin
Oxford, MA
I thought that one of the benefits of an F450 is a tighter turning radius than the F350 due to the way the front end is set up. Is that still the case? Even if the rest of the truck is pretty similar to the F350, this could be something that makes the DRW palatable over the SRW. I know this is a RAM forum, so not stumping for the F450, but based on OPs concerns, it's only fair to get all the info out there to make an informed decision. For the record, I love my RAM. But I too am thinking about a large TH 5er in the future and had/have similar concerns as OP, so this thread spoke to me....Good luck, whatever decision you make.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
That's better than mine. I have a stripped out 3500 Tradesman SRW 4dr, Cummins HO, 3.73 rear and the door sticker lists the GVWR as 11,800.
JerryETX
Elgin, TX
I believe you are correct at least on the Ford. I'm not sure about a Ram which is why I didn't mention it.
DOTallstar
NY
Got a ‘16 3500 SRW Crewcab CC, Eby 9’ flatbed, gooseneck hitch, ICC bumper/hitch, 6.4/SLT/Asin/4.44 gears/22 gallon AND 52 gallon fuel tanks…. I suggest a similar setup for yourself. A good combination of luxury and workhorse.
danielmid
Southeast WI
2015 Sport 4x4
Drive a Chevy HD...You'll appreciate the turning radius the RAM has. Chevy's suck to make uturns in...
I know this is a Ram forum but a few of the biggest rigs I've seen are using F-450s and those supposedly have an amazing turn radius with the wider front axle.
Reticle918
